Chapter 2
Getting started[edit]
Software overview[edit]
- The Visual and Graph System
- Sequence Testing
- Calibration
- Data Logging
- Database Functionality
- The Device Driver System
- Report generator
- Excel Exporter
- Different types of tests can be performed, fully automatically, after each other (Sequence testing).
Conventions[edit]
File
Open
EUT
Hardware requirements[edit]
The RadiMation® software makes extensive use of data calculations, bus interactions (to control the test equipment) and screen interactions (for the use of graphs). Because of this the processor performance is very important and a dedicated PC for RadiMation® is required. Running other programs on the same computer can cause compatibility problems and is not supported. Programs which are supported are the programs used by RadiMation®, such as Microsoft Word, Excel and MySQL.
Memory[edit]
RadiMation® needs a considerable amount of memory to perform at its best. We recommend that you have at least 2 GB (GigaBytes) of free memory available, but more if possible. Free memory is defined as the amount of free RAM without having to use the swap file. Thus, not the specification of the total amount of memory that the machine has. The following steps are to help you determine the amount of free memory in your PC:
If the amount of free memory is less then 2 GB, there are several options to obtain more free memory. Depending on the configuration and situation, the following options are available:
GPIB card[edit]
Software requirements[edit]
The Microsoft .NET Framework 4.8 is also required. For all supported Windows operating systems, this is already installed by default.
Microsoft office[edit]
It is required to have a supported, licensed and working version of Microsoft Office Word installed on the PC. This should be at least Microsoft Word 2016 or higher, as Microsoft Word 2013 and lower has no mainstream support anymore from Microsoft. RadiMation® uses Microsoft Office Word to generate and print the printouts, besides creating the reports. The RadiMation® report generator can create reports in the following formats:
Installation[edit]
Software installation[edit]
- CAL_File
- CONFDVDR
- COR_File
- EUT_File
- LLF_File
- Printout
- RGO_File
- RGT_File
- SEQ_File
- TSF_File
| Argument | Purpose and explanation |
| /SP- | Disables the 'This will install ... Do you wish to continue?' prompt at the beginning of the setup |
| /SILENT | Instructs the setup program to be silent |
| /VERYSILENT | Instructs the setup program to be very silent |
| /SUPPRESSMSGBOXES | Instructs the setup to suppress message boxes |
| /LOG | Causes setup to create a log file in the user's TEMP directory |
| /LOG="filename" | Same as /LOG, except it allows to specify a fixed path/filename to use for the log file. |
| /NOCANCEL | Prevents the user from cancelling during the installation process. |
| /NORESTART | Prevents Setup from restarting the system following a successful installation, or after a Preparing to Install failure that requests a restart. |
| /DIR="x:\dirname" | Overrides the default directory name |
| /HELP | Shows a detailed explanation of all the command line parameters |
| Note: | We strongly advice to make a complete backup of all user files and directories (e.g. Device driver configuration files/TSF/Sequence/Correction/Calibration and EUT files) before installing a RadiMation® update. |
Updating device drivers[edit]
New installation[edit]
Update[edit]
To update the RadiMation® software, the user must have the rights to read and write in the RadiMation® folder, which is normally located in the 'C:\Program Files (x86)\Raditeq\' directory.
Daily usage[edit]
Software protection key[edit]
Software configuration[edit]
Password protection[edit]
Directories
Test engineers[edit]
- The default client
- The default manufacturer
- The default test site
Directories
Default Units[edit]
- Radiated Immunity
- Conducted Immunity
- Radiated Emission
- Conducted Emission
- Pulsed Immunity
- Antenna Diagram
- RadiCal
Graphics configuration[edit]
Database Configuration[edit]
Language Selection[edit]
RadiMation® supports multi-language use. This means that the software package can be operated in several different languages.
In addition, the multi-language support allows for easy translation from English to most other languages.
| Note: | Not all languages are currently available. Please contact your local reseller for language availability. |
Product Standard[edit]
| Note: | When a product standard is selected or added in the 'EUT' window, the data of that standard is copied into the EUT Document. At that moment a copy of the data of the standard from the configuration is made. This means that, if the configuration of a standard in the 'Configuration' window of RadiMation® is changed, the data in the EUT file will still have the old data of the standard!!! This is as it should be, because this is the information of the standard that is used at the time that the EUT was tested. |
Basic Standard[edit]
To delete a piece of test equipment from RadiMation®, select the Test Equipment from the pull down menu and click the 'Delete' button in the top of the window. A confirmation window will appear.
A menu will open (at your mouse pointer) with the available devices for that Device Type.
Edit the information about your ‘user configurable device driver’ in the 'Device Driver Settings' window.
| Note: | Passive equipment, such as antennas, current probes, cables etc., also need a device driver. This is required because RadiMation® has to know a number of parameters for these devices. Among others the following information is relevant:
EUT files[edit]
Creating a new EUT file[edit]
EUT window overview[edit]
Limit line files[edit]
Creating limit lines[edit]
| Enter a file description for the limit line in the Description field (e.g. Limit Line Example). |
| Enter frequency-value pairs for the limit line in the Data field (see ‘Enter, edit & remove data pairs’ below). |
Setup the Options field:
| Setup the Detectors field by selecting one or more detectors. During emission tests, RadiMation® will check if the measured emissions are below the limit line(s). To perform this check in the correct way, the software must know for which detector(s) the limit line is valid. |
| Setup the NB/BB field by selecting the option(s) Narrowband and/or Broadband. |
Saving limit line files[edit]
Correction files[edit]
| Enter data pairs for the correction value in the Data field (see ‘Enter, edit & remove data pairs’ below). |
| Select either logarithmic or linear interpolation.
Saving correction files[edit]
Viewing test data[edit]
- Time and date of the test
- Test engineer
- Notes
- Ambient information
- Test graphs
- Test configuration data
Printing test data[edit]
| Warning: | Printing from RadiMation® will be done by your default Windows printer (with its default settings). To change the printer/settings used by RadiMation®, please change the default printer settings in your Windows environment. |
Report generation[edit]
Ambient information[edit]
The first test[edit]
