Release Notes 2016.1
We are proud to deliver you Version 2016.1 of our RadiMation® EMC Test software. This 2016.1 version is the result of several major improvements that we have done. This release is completely based on the Microsoft .NET development framework, which ensures that we can fully support future operating systems.
We include several improvements and new functionalities in version 2016.1, the most important improvements are:
  • Amplifier Linearity check according EN 61000-4-3 and EN 61000-4-6
  • RadiLog communication monitoring
  • Graphs will remember if they are shown, and will then automatically be re-shown
  • Multiband Immunity Minimum performance testing
  • Several user interface and usability improvements.
  • Report generator fixes.
We trust that we have incorporated these new feature in such a way that it is useful for several customers that have been requesting these functionalities.
This letter contains all the information that is needed before your system is upgraded. If you have any additional questions or remarks please let us know through your reseller, or contact radimation-support@raditeq.com.
Installation[edit]
Backup[edit]
  • Correction files
  • TSF files
  • Sequence files
  • Limit Line files
  • Device driver configuration files
Be advised that:
  • It is not possible to run two (or more) different versions at the same time without risking a software crash. Close other instances of RadiMation® before starting another version!
  • Raditeq cannot be held accountable if information is lost because two different versions of RadiMation® are used at the same time.
  • The user needs to have the rights as described in User rights and installation.
Installation[edit]
Updating device drivers[edit]
  • Correct control of the used measurement equipment
  • Validation of the software according to internal quality standards
  • Possible verification and comparison of measurements on a 'known' EUT
Solved items[edit]
See below the list of all the issues that have been solved in RadiMation® version 2016.1 since version 2015.1
RadiMation version 2016.1.13[edit]
  • #3168: Is amplifier protection working in a multiband immunity test
  • #3517: Radiated Immunity: Level is going too high
  • #4397: Forward power protection file for an Amplifier is ignored if power is already limited
  • #4586: Amplifier limit completely ignored
  • #6304: Reference level should be requested to ensure a correct calculation of the measurement value
  • #6855: Limitation of a Multiband Immunity test on the current is levelling just above the limit
  • #7437: R&S FSEK 30: Function not available;BAND:MODE:FFT OFF
  • #7468: Quasi peak measurement of Analyser sometimes has a difference
  • #7634: R&S FSEK 30: Function not available: FFT OFF
  • #7786: Regular expression of RFS2006B antenna tower is incorrect
  • #7787: Driver Vectawave VBA230-22 and VBA1000-150
  • #7789: Advantest TR4172 Not all bytes are written to the GPIB-Board within the timeout period
RadiMation version 2016.1.12[edit]
  • #1784: Agilent E4416A/E4417A (EPM-P series) should have option to measure Peak power
  • #5629: Include option to 'Run Radimat.exe' after Device Drivers setup program
  • #7080: Driver: EM test CWS 500N2.2
  • #7099: Changing Powermeter advanced Measure setting is not enabling other settings when only the value is changed
  • #7301: Driver Messtechnik Motion detection system
  • #7475: Extend Field sensor device driver configuration with advanced Monitoring measurement settings
  • #7476: Wrong measurements at first frequency point of the test
  • #7615: Does the driver of the Power meter E4417E performs reading of the peak value?
  • #7641: Measurements take a long time with the Advanced ESU 40 / FSV as a powermeter
  • #7650: Voltage test level Voltage measurement (Powermeter) is not measured
  • #7659: Agilent N5182A error the measurement device does not support this functionality
  • #7666: Driver R&S EZ17 current probe
  • #7668: Driver: Schaffner/TESEQ CDN S150
  • #7669: Driver Schaffner/TESEQ CDN USB/p
  • #7672: Driver: MEB CDN S25
  • #7673: Driver: MEB CDN S1/50
  • #7674: Driver MEB CDN MEB KEMZ801
  • #7676: Driver: Switch matrix HP3488A
  • #7677: Driver: NRP8SN
  • #7678: Driver: Directional Coupler RFPA RFC801000 -40-150
  • #7679: Driver: Directional Coupler RLC CHP-1040-D-40-40-FF
  • #7681: Driver CDN Schaffner USB/c
  • #7683: Driver CDN Teseq M116
  • #7684: Driver: NRP8 Power meter
  • #7698: EM Powermeter unable to pass the checkdevice.
  • #7702: Driver: ETS-Lindgren's 8100-045 RF Power Amplifier
  • #7703: Driver: Werlatone C10762 Coupler
  • #7704: How to use a manual Turn Table during Multiband Emission?
  • #7709: Sensata Olimex SENT (Configurable AD Converter) Timeout before operation completed
  • #7710: Spectrum Analyser (ID1465) Input 2 (LAN): SPecific System Error: -410, "Query interrupted"
  • #7730: False graph of result of N9000-series measurement: High emissions
  • #7739: Agilent E4417A Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
  • #7747: EMTest UCS500N + Phase 3 coupler Error
  • #7749: SetEndOfString is not used
  • #7762: Ability to use the Configurable AD Converter for PMX
  • #7771: R&S ESI as powermeter is measuring too fast
  • #7772: The measure time is not always correctly set when the receiver is used as a powermeter
  • #7774: Correction of resistor is not used in magnetic field measurement
RadiMation version 2016.1.11[edit]
  • #4272: Wrong values tuned frequency range HP85685A Preselector
  • #7008: Reflected power too high
  • #7082: CE test 20V problem
  • #7279: End of Surge test is not correctly detected on a Teseq NSG3040
  • #7461: Unable to use formula option in AD converter
  • #7485: Driver Signal Generator Keysight 33522B
  • #7515: SRQ errors are generated using Tektronix TDS5034B
  • #7542: Driver Amplifier IFI S41-250
  • #7624: Driver Keysight Amplifier N4985A
  • #7631: Agilent Technologies N9038A Scanning Receiver: Device is not aligned error
  • #7638: Maximum selectable RBW for the Analyser As Powermeter settings is 50 kHz
  • #7642: Agilent N9038A set RBW raised error Data out of range; the value 0 was clipped to the minimum value of 10
  • #7651: Wrong frequency range Teseq CBA 1G-1000
  • #7654: Configurable Amplifier custom frequency range is not retained
  • #7693: Device driver configuration of the RSS1006A (CTR1001S) field sensor
  • #7699: Re-enabling the selectioning of peak markings
  • #7763: How to launch programs?
RadiMation version 2016.1.10[edit]
  • #2533: Power conservation is not clearly described in the user-manual
  • #3917: Nonexistent peak and wrong final measurement with PMM during conducted emission multiband tests
  • #4550: Driver: EM-Test Signal generator CWS 500
  • #4596: Problem with PMM in latest version
  • #4821: Driver Tektronix 3000 for fixed voltage test
  • #5989: Driver: emtest CWS500N for IEC61000-4-6
  • #6328: Driver FSV-3 as powermeter
  • #6383: Error -222 Data out of range;INP:ATT 50 DB while deinitializing a R&S ESL 6
  • #6767: Too much reflected power in combination with the RadiField
  • #6955: Error too much reflected power due to RadiField reflected power value
  • #7030: Driver: CWS500N2 EMTEST
  • #7107: Incorrect LimitLine values
  • #7232: R&S ESI26: Data out of range: 1 Hz RBW during powermeasurement
  • #7323: Prana MT400 Not all bytes are written to the GPIB-Board within the timeout period
  • #7324: Prana MT400 Amplifier still in operate
  • #7325: Prana MT400 Amplifier not always to RF-ON
  • #7446: Reflected powermeter measurements data is incorrectly shown
  • #7463: Test duration takes a lot of time as compared with a old software used before
  • #7505: Frankonia FC 06 Turntable Error -33072 (Invalid target position)
  • #7508: End frequency is not correctly stored in an attenuation/gain system calibration
  • #7524: Driver NOVOTRONIK GTS5611 switch matrix
  • #7525: Driver NOVOTRONIK GTS5601 switch matrix
  • #7530: Selecting 'AD converter selected in testsite' as monitoring input device is default selecting 'nothing' instead of channel 1 resulting that nothing will be measured
  • #7553: How to configure default graph log or linear scaling?
  • #7554: Driver Advanced settings for ESU 40 as a powermeter
  • #7592: RadiMation does not trigger a GetCurrentStatus after Operate and PowerOff
  • #7599: Driver: AR FL7218 Field Probe
  • #7601: RadiPower RPR2006 powermeter Windows device drivers
  • #7602: Bonn Testsystem
  • #7605: GPIB-Board is not controller in charge (CIC) GPIB: ECIC
  • #7607: Shifted Report Generator table
  • #7620: PI EFT singleband Report generator codes empty
  • #7648: Missing keywords for EUT calibration Harmonics
  • #7686: Wrong title above emission plots
  • #7687: Progress bar in PI MB tests is not visible after second sequence
RadiMation version 2016.1.9[edit]
  • #1828: Additional total max hold graph window
  • #1957: Wrong message when no impedance file is selected
  • #3001: Manual is missing information on how the corrections (and the to be used columns) should be used
  • #3444: LISN ESU User port lan device
  • #4975: Sorting of table frequency data in the Report is incorrect
  • #5815: Driver Agilent N1911A powermeter
  • #5863: Error File is not found: %s when opening TSF or after crash
  • #5994: Test initialization failed for Agilent N5181A-506 with Pulse Modulation option
  • #6177: CARAD EUT Controller driver raises Ethernet not connected errors
  • #6420: Exported RAW data is still showing unit information
  • #6752: The Device Specific value 'Power' of the powermeter should be renamed to 'Uncorrected Power'
  • #6902: Keywords TEST SITE EMAIL ADDRESS and CLIENT EMAIL ADDRESS are not working anymore
  • #6933: Driver Luthi MDS 20 Absorbing Clamp
  • #6934: Driver EMCO 3158 Antenna
  • #6935: Driver CBL 6144 antenna
  • #6936: Driver ARA DRG 118a Antenna
  • #6944: Driver Holaday HI4422 FieldProbe
  • #6951: Driver Schaffner NSG 2070
  • #6961: Description for this error is not available is shown during startup
  • #6964: Ability to have Start and Stop Dwelltime events for the NI 6218 switch matrix
  • #6993: RadiGen RGN6000B Setting the output level raised an error
  • #7010: Use a NI USB6501 to switch between forward and reflected power
  • #7024: Problem solving for the test setup of a Conducted Immunity Mil Std Calibration
  • #7025: Driver Rohde & Schwarz ESW26
  • #7040: Marconi signal generator doesn't respond on *STB?
  • #7197: Driver Generic National Instruments Output Switch
  • #7275: Switching matrix OSP 120. Relay K11 on slot 3 doesn't switch
  • #7291: RadiGen RGN6000B HF Returns error: -222 Data out of range
  • #7298: TCPIP Communication is not working correctly for the TDEMI
  • #7304: TCPIP controlled TDEMI Powermeter raises a crossthread error message
  • #7311: Driver Aaronia Spectran HF-60100 V4 X
  • #7314: Insert additional frequencies
  • #7340: Driver AE Techron 7224
  • #7341: Driver OSR C21A8
  • #7342: Driver TESEQ CIP 8136
  • #7343: Driver Rohde & Schwarz ESW8
  • #7345: Driver Agilent 87405A pre-amplifier
  • #7346: Driver Agilent 34401A
  • #7348: Driver Agilent 54831B as oscilloscope
  • #7349: Driver Agilent 34401A
  • #7352: Driver Antenna Schwarzbeck BBHA 9120J
  • #7353: Driver Antenna Schwarzbeck STLP 9128ES
  • #7354: Driver Directional Coupler werlatone C7354
  • #7356: Driver AR 500W1000B
  • #7379: R&S NRP only channel a is working
  • #7381: R&S ESL6: Several GPIB communication problems
  • #7397: RadiField RFS1006B Returns Error 521. Driver 3 current out of range
  • #7403: Communication with plugin cards is lost
  • #7424: Keysight N9083A runs incredibly slow after 3.6 GHz in scanned receiver mode
  • #7433: Not all data is recorded in RE GTEM
  • #7466: RadiField RFS1006B Returns Error 560. Communication amplifiers failed
  • #7478: EFT/Surge and VDI Report Generator keywords overview
  • #7480: Question regarding R&S IMS device drivers
  • #7483: Update the RadiMation software requirements
  • #7486: RSW1024S Interlock: Not all bytes are written to the GPIB-Boadr within the timeout period
  • #7487: RadiField RFS1006B Returns Error 526. time out error GPIB
  • #7488: RadiField RFS1006B Returns Error 1087. Signal power went to high (-6dB) during power delivery test
  • #7493: RadiField RFS1006B Disconnecting error: No amplifier connected
  • #7494: Kalmus amplifiers cannot be controlled. GPIB: No listener on the bus
  • #7495: RadiField RFS1006B Power off after disconnecting device
  • #7502: Extend the IDocument interface to also return an unique IDataIdentifier
  • #7503: Change the implementation of IGraphElement::DataIdentifier to also use the IDataIdentifier of the data document as the parent IDataIdentifier
  • #7504: List of available graphs should use the IDataIdentifier of the graph element
  • #7510: SetMicroSecondsDelay is ignored/not used when set from the 'AfterStreamConnectConfiguration'
  • #7516: NI DAQ Error 6009 Unable to keep up with the hardware acquisition
  • #7521: How can the complete graph data of the polar plot be exported as table data?
  • #7534: SMR40 driver slowed down in communication
  • #7538: How to disable the power delivery test?
  • #7539: Driver Antenna BBA 9106
  • #7541: Driver PowerSensor Agilent N1911A
  • #7543: Driver Antenna SBA 9113
  • #7547: The used and installed version of the NI GPIB Library should be logged in RadiLog
  • #7548: Setting the VISA communication setting to the Visa-ID is automatically being changed to RS-232
  • #7550: Driver Broadband Preamplifier Schwarzbeck BBV 9743
  • #7556: Extend the license that the user agrees that RadiLog and other reported gathered data being send might contain confidential content
  • #7558: Driver Keysight EXG N5173B signal generator
  • #7562: Driver SG6000 Signal Generator
  • #7564: Driver Measuring amplifier B&K 2636 Analog, 1 channel (via GPIB now)
  • #7570: Driver Directional Coupler Warlatone C9475
  • #7571: Driver Teseq CDN M016S
  • #7572: Driver Teseq CDN S501AS
  • #7573: Driver CDN S751AS
  • #7574: Driver Werlatone C5982 Dual Directional Coupler
  • #7577: Easy merge of multiple EUT Attenuation/Gain corrections to one correction
  • #7583: ETS-Lindgren HI-6053 error No match was found in the specified regular expression
  • #7584: Driver Generic NI DAQ mx AD Converter device driver
  • #7587: How to configure a limitation on power during a DO-160G/ED-14G BCI test?
RadiMation version 2016.1.8[edit]
  • #4514: Support the +10 dBm output of the RadiGen
  • #5705: Device driver Baudrate and terminator character settings are not used
  • #6427: Please include in the manual that the graph trace description is a valid Report Generator keyword
  • #6800: Exported AD Limit does not have the same color in the report
  • #6970: Problems and overrange detected during CI Calibration
  • #7101: Pulsed Immunity ESD is not removing selected tab
  • #7195: Driver Amplifier VBA1000-275
  • #7248: Testing a frequency above 1 GHz takes much more time than the configured dwelltime
  • #7313: Reopening test files gives error: Object variable or With block variable not set
  • #7426: Reflected powermeter is required when performing a Multiband fixed power test at Forward powermeter level
  • #7450: Example of an emission measurement
  • #7451: RadiLog search function does not always match
  • #7460: RS232 communication settings are not updated
  • #7469: Logarithmic step measurement using the R&S ESCS causes a crash
  • #7491: Measurement with N9038A stops at 400 MHz.
  • #7517: R&S ESCS 30: Not all bytes are written to the GPIB-BOARD GPIB:EABO
  • #7531: Configurable AD Converter is using input range min max as multiplier
  • #7546: Some PC's suddenly raise NI GPIB hibernation errors. A PC restart is then needed
  • #7552: TCPIP controlled EUT monitoring of an Amplifier
RadiMation version 2016.1.7[edit]
  • #4026: 10dB Min Attenuation is not switched OFF with the TDEMI
  • #4030: TDEMI controlled LISNs
  • #4674: Device driver system is currently not usable
  • #4828: Guide how to configure and use RG templates
  • #5600: RadiMation crash after Gauss TDEMI device driver check
  • #5886: Driver R&S SMR20 Signal Generator (with internal pulse modulation)
  • #6252: GAUSS Instruments TDEMI device firmware update now causes a timeout error after reset
  • #6382: EM TEST UCS 500 Surge generators not possible to configure the GPIB address
  • #6622: Driver: Different models for the Gaus Instruments TDEMI
  • #6630: Add RadiLog messages to the DeviceDriverBase class
  • #6647: RadiSense 6 fieldprobe connected by Radicentre 1 is raising an error
  • #6791: Driver RadiField 2000 series as EM Field generators
  • #6893: Add events when starting tests
  • #6910: Driver: TDEMI X6 Spectrum Analyser
  • #7037: Aplying modulation out of dwell time period gives odd peaks
  • #7038: Disabled modulation at frequency steps
  • #7063: Driver: Gauss TDEMI X
  • #7110: Closing of the virtual Field sensor measurement window
  • #7118: EM-Power 7002-006 powermeter Windows device drivers are not working
  • #7137: Does Minimum performance take the minimum and maximum of every AD channel into account?
  • #7181: Driver: euro EMC RSC
  • #7184: Timeout on checkdevice TDEMI X3
  • #7196: Driver: Amplifier Teseq CBA 3g-050
  • #7209: emtest PFS500 SRQ line of the GPIB bus is raised by another uncontrolled device.
  • #7224: AD convertor device trough MODBUS
  • #7225: AD Convertor using OPC to connected with CAN USB convertor of PEAK with CANopen protocol
  • #7290: RadiField RFS1006B Returns error: 574
  • #7296: Cant add the HP8594E as real power meter to the EUT file after installing the latest drivers
  • #7297: Check of a TDEMI is crashing if the device is not connected
  • #7300: Driver Schwarzbeck NNBM 8126G seems to not work properly
  • #7303: RadiField amplifier is not put into operate
  • #7319: Driver: emtest CWS500N1.3
  • #7336: EMTest EFT500
  • #7382: Does RadiMation software use "Dwell for Combination of RF Immunity CW,AM,PM"
  • #7385: Driver: EMTest TSS 500
  • #7390: Connect button on the VI Amplifier window is not shown
  • #7392: Selecting a VI from the Devices menu shows a new VI window, even if the VI is already open
  • #7394: Update of the table of a graph, sets the selection to the first row again
  • #7402: RadiPower RPR3006W questions
  • #7405: Request Radimation driver for Rohde & Schwarz FSW-26 Signal Ananlyzer
  • #7409: Software Protection Key could not be found
  • #7447: Field Sensor FP5080 is returned unexpected values
RadiMation version 2016.1.6[edit]
  • #4760: First band data seems to be lost with 10kHz tot 30 MHz Multiband test
  • #5864: Preamplifier and reference setting have no effect for the ESL6
  • #6086: Driver for the Delphin Technology Expert Key 100 box
  • #6259: ALL RADIATED EMISSION TESTS is not replacing keywords of corresponding tests
  • #6279: Readout of RadiPower in RadiMation Free raises overload at 0 dBm
  • #6663: Provide same functionality as RadiMon
  • #6687: Driver: Luthi MDS22
  • #6708: No graph traces in the exported plots in the report for lower frequencies
  • #6766: Measuring settings Lines/Neutral with LISN
  • #6882: System requirements for RadiMation
  • #6883: Using radiated immunity for shielding effectiveness
  • #6915: Driver: Schwarzbeck BBA 9106 antenna
  • #6916: Driver: Schwarzbeck MDS21 Absorbing clamp
  • #6922: Driver: Teseq CBA 230M-80 amplifier
  • #6923: Driver: Teseq PMU6003 Powermeter
  • #6924: Driver: TESEQ DCP 0100A Directional Coupler
  • #6925: Driver: Teseq KEMZ 801 Injection Clamp
  • #6926: Driver: Prana MT440DC Amplifier
  • #6927: Driver: Teseq NSG437 ESD generator
  • #6941: Driver: Rohde & Schwarz NRVS
  • #7006: Question: SMB 100A SignalGenerator modulation
  • #7048: Selection of 'Neutral' LISN line is wrong when restarting last TSF
  • #7062: Unexpected dips in measurements when rechecking peaks
  • #7129: Corrupt Customized.xml will raise an error and crash RadiMation
  • #7211: VDI Object reference error
  • #7229: HP 8594E Spectrum analyser is not following signal generator.
  • #7237: Report Generator graph only shows peak markers without the trace itself.
  • #7243: Probe numbers are not shown anymore in the Field inputs dialog
  • #7273: Behaviour of the ||EUT|DESCRIPTION|| Report Generator keyword
  • #7280: Tabs of Device specific settings on the devices Virtual Instrument window are not shown
  • #7282: Driver: Schaffner NSG 3025 BurstGenerator
  • #7286: Vectawave amplifier is in endless loop, when an error is present
  • #7317: RE MB build in preamplifier used at higher allowed frequency
  • #7339: Driver: Agilent E4412
  • #7350: Driver: AR 500W1000B
  • #7359: Is the standard Din-EN 61000-4-6 supported through subsitution method?
  • #7377: Clear button should be pressed automatically when the VI window is closed
  • #7414: Device not connected errors for the PMM 7010 Low Input and Hi Input drivers
  • #7430: No communication (device not connected) with Field Sensor FP5080
  • #7431: RFS is not working and keeps powering off
  • #7626: Final measurement of Average detector is lower than the average value of the prescan
  • #7632: Not all emission tests are performed of the configured bands
RadiMation version 2016.1.5[edit]
  • #5344: ESPI -222 Data out of range error
  • #5434: Driver: Agilent N9038A, 44 GHz option
  • #5480: Throw error or warning when 'Step Size clipped to nearest value allowed' for Agilent MXE N9038
  • #5694: Driver Amplifiers Ophir 5225E / 5264E / 5274E
  • #5786: Possibility to specify the 'auto-switch off' time of the PMM EP600-series probe
  • #5956: Units change from dBm to W in the Power Meter Module does only change unit text
  • #6273: Logarithmic step frequency for the Agilent N9038A
  • #6310: Reference level of the N9038A is not set to the specified reference level in the TSF
  • #6458: Several improvements and issues for the Agilent MXE EMI Receiver N9038A
  • #6682: Driver Schwarzbeck MDS21
  • #6683: Driver Schwarzbeck MDS22
  • #6684: Driver Schwarzbeck LISN's
  • #6685: Driver: Schwarzbeck VULB 9162
  • #6688: Driver: Bonn Elektronik amplifier BSA 0125-25
  • #6689: Driver Bonn Elektronik BSA series amplifiers
  • #6718: Numbers on Analog scale of Virtual instrument should be updated when unit is changed
  • #6792: Agilent N9038A: Non EMI average detector is change due to physcial constraints
  • #6921: Driver: Agilent N5171B-506 + UNT
  • #6940: Driver Bonn BSA 0122-20
  • #7092: Longer time till sleep mode Narda EP600/EP601
  • #7163: Errors connecting Lutron field probe
  • #7170: Actual RH values no longer visible.
  • #7173: Searching for possibility to download latest RadiMation version for driver release
  • #7175: Wrong commands for Maturo ncd for antenna and turntable
  • #7185: Unable to install the newest version, only HTTP and FTP are supported
  • #7188: Advantest TR4172 No match was found in the specified regular expression
  • #7194: Driver: Antenna Tower Inn-co GmbH MA4000
  • #7208: Checksum error with the EMTEST CWS500N1.2
  • #7217: Unexpected response from the Narda EP600 after filter setting command
  • #7220: Driver: Vectawave VBA1000-1000
  • #7238: Report generator text unexpected in bold.
  • #7241: Sending an error report takes a long time (roughly 1 minute)
  • #7246: Forward power and signal power graphs are not shown anymore in already performed tests
  • #7302: Re-measuring peak values increases the measurement with 10 dB
RadiMation version 2016.1.4[edit]
  • #423: Configuration of customer database is not retained
  • #4809: Driver: Hameg HMS3010 Spectrum Analyser
  • #5211: Driver: Maturo NCD controller advanced error checking
  • #5228: HP8594E GPIB error
  • #5314: RadiMation database table and fields are sometimes not retained
  • #5492: System error checking on HP 8562/8563 causes communication errors
  • #5969: R&S ESU EMI receiver is only set to integer frequency values
  • #6175: Driver: Thermo Scientific EMCPro-PLUS
  • #6429: Peak Maximise settings change doesn't work
  • #6795: Graphs and table overviews are mixed-up and not correctly displayed
  • #6810: Driver: Lutron EMF-819 Fieldsensor
  • #6839: Forward power column in the table of Amplifier linearity is not showing the first powerlevel
  • #6871: Driver: Hameg HM8135
  • #6957: Not possible to export a fixed field to a CAL file, errors is shown that modulation was used is shown while this is not the case
  • #7004: Pasting large data (19000 rows) into a COR file is crashing RadiMation
  • #7032: GPIB communication is slower with newer drivers
  • #7033: Unknown error message RadiField. Error 530
  • #7045: Cannot find Modulation source in the currently active testsite
  • #7052: Crash: CE MB Antenna Terminal measurements
  • #7056: 1st correction file selection of antenna shows: 'Select a correction file'
  • #7057: HP 8594E analyser as a power meter returns Not all bytes are written to the GPIB-Board
  • #7061: Graphs and table of Amplifier linearity test is unlogical
  • #7075: sorting of columns of the peak table is not working correctly
  • #7076: Exporting field strength to calibration is not working, because a modulation is selected, even if 'No Modulation' is selected
  • #7084: HP85xx-series: Incorrect measurement: Emission values up to 330 dBuV/m
  • #7086: Setup downloads .NET 4.6 instead of .NET 4.6.1
  • #7094: Bonn amplifier should be placed in REMOTE, also on GPIB
  • #7105: Unlogical Red cross in AD Configuration dialog
  • #7108: Selection of CapacitiveClamp on EMTest UCS500N not correct
  • #7113: Polar graph is not drawn correctly, when the window has been maximized
  • #7117: Driver TTi TGR2050 Synthesised RF Generator
  • #7119: RadiMation does not start up after modifying global/standalone directory
  • #7124: Object reference not set to an instance of an object: Frequency drawing of bands control
  • #7127: Font of the legend on the polar plot is much smaller than on the frequency graph
  • #7128: Index was outside the bounds of the array error 536879965
  • #7136: Unable to report error manually
  • #7138: Issue with our home made 40 channel AD Converter
  • #7141: AD Converter error during test initialization
  • #7145: Output of multiple channels using LeCroy WaveSurfer Channel switch matrix driver during single band test
RadiMation version 2016.1.3[edit]
  • #6311: Crash when maximizing the MB Emission test result window
  • #6333: RadiMation crashes when maximizing the multi-band emissions results screen
  • #6430: Radimation crash if radiated emission window resized during measurement
  • #6686: Driver Luthi FT/FTC series absorbing clamps
  • #6715: Run-time error 5 procedure call or argument is not valid in RADRESRC.DLL
  • #6896: Error timeout with Maturo MCU controller
  • #7017: SYST:ERR -222:Data out of range for RadiGen
  • #7020: Limit lines are not shown automatically at the end of the test
  • #7022: Maximum cable length is not included in the ||EUT|CABLE TABLE|| in the report
RadiMation version 2016.1.2[edit]
  • #5587: Old LLF is not removed and not replaced with newly added LLF
  • #6393: Graph is covering a rang and analyser is performing a test outside the specified bands
  • #6464: Automatic search of highest peaks is changing graph shape
  • #6466: Driver R&S FSL
  • #6470: Driver R&S NRP2 powermeter
  • #6518: FSU 3 error -200 Option ot available INP:PRES:STAT ON during test initialization
  • #6723: Broadband disturbances are showed as peaks
  • #6804: AD converter values of older tests are not correctly showed in latest versions
  • #6865: Implement retry of Software Update used for RadiField amplifier firmware updating
  • #6903: Add an additional 'Maximum cable length' field for a cable in the EUT
  • #6904: Add a note field to a cable
  • #6912: RadiLog icon disappears when pinned to the taskbar
  • #6972: RadiLog is not able to write to temporary directory
  • #6981: Setup program doesn't check if .NET framework 4.6.1 is installed
  • #6985: Advantest TR4172 as powermeter is not correctly measuring
  • #6986: RadiLog icon disappears when pinned to the taskbar
  • #6988: R&S FSU: Not possible to select 50 MHz RBW
  • #6991: How to determine the compression level using a constant output power test
  • #6992: Software update will crash RadiMation when a connection error is found
  • #6993: RGN Setting the output level raised an error
  • #6994: R&S FSU undefined header -113 INP:TYPE INPUT1 error
  • #6999: Time interval of table data from a multiband immunity test in the report skips rows if a large delay was present during the test
  • #7005: Limitlines are not shown when old test results are opened
  • #7011: RGN software update panel should be hidden
  • #7012: Implement checking of system errors for RGN
  • #7014: Report Generator can be used without a license
RadiMation version 2016.1.1[edit]
  • #5988: Driver Teseq ITS6006 for IEC61000-4-3 & CISPR11 as Signal Generator
  • #6556: Update the CD Start menu for 2016.1
  • #6558: Update version and copyright years to 2016
  • #6965: Add ability to return the RAW AD Converter value
  • #6983: Empty tabs and no labels are shown after fresh installation
  • #6998: Data table from Multiband Immunity in the report generator is always using time interval mode
  • #7003: Device check of the R&S SMB100A is unsuccessful
RadiMation version 2015.3.6[edit]
  • #4575: Connecting another RadiPower Virtual instrument when another RadiPower is continuously measured, corrupts the data of the continuously measured RadiPower
  • #5455: Error wrong argument during Burst test
  • #5471: Burst measurement Unhandled exception Object reference not set to an instance of an object
  • #5876: App. Note 100: Enhanced Status Window usage and description included in the manual
  • #6095: Driver: Bonn Elektronik BTA 0122-3000
  • #6251: R&S ESR7 specific System Error: -222 Data out of Range DISP:TRAC:Y:RLEV:0.0103DBM
  • #6312: Timeout in communication with R&S ESPI after QP measurement
  • #6441: Frankonia FC is raising an -101 error during test initialization
  • #6473: Cannot access a disposed object frmVIPowerMeter
  • #6623: Driver: Frankonia ECU-3 / ECU-6
  • #6713: Driver Keysight 33521B Signal Generator
  • #6714: How can to get some specific trace data in the graph?
  • #6878: Comm failed with Powersensor PMM6630
  • #6888: Driver: Rohde & Schwarz ESR 26
  • #6890: Reportstatus of Kom ik hier? is shown during RPR3006W
  • #6898: EventLogData in list controll to be made possibly visible in RadiMation.
  • #6899: Event Window
  • #6913: EUT window is not correctly sized on 1024x768 beamer
  • #6939: Lasercode to activate the RadiSense fieldsensor laser inside the RadiCentre
  • #6942: Configurable AD-Convertor for asynchronous data
  • #6592: Update to .NET 4.6.1
  • #6954: Prana AP32DR312 amplifier serie is infinitely polling status when warnings are returned
  • #6962: Configurable AD Convertor device driver cannot interpret multiline result
RadiMation version 2015.3.5[edit]
  • #2848: Regulated testlevel should be above requested testlevel if testlevel could not be regulated within the tolerance
  • #3962: A limit in a Multiband CI test is only checked when power is limited by amplifier limitation
  • #3963: Ramp method in CI Multiband doesn't remeasure the generated voltage
  • #4264: Field level is less than set
  • #5371: Initialization of Prana AP32 DR216 Amplifier is always successful
  • #5978: Driver: Prana DT70D Amplifier
  • #6134: Driver: Teseq ITS6006 for IEC61000-4-3 & CISPR11 as Power meter
  • #6214: Driver: Prana DP600 amplifier
  • #6253: Driver: Prana DT70S amplifier
  • #6288: Driver: Prana UX55 amplifier
  • #6318: Driver: Prana SV70D amplfier
  • #6319: Prana LT320D amplifier doesn't work
  • #6358: RadiField and RadiGen doesn't switch to local at the end of a test
  • #6374: Driver: Prana MT700 amplifier
  • #6396: NI DAQ USB 6218 AD Converter read values are delayed
  • #6425: Driver R&S NRP-Z91 controlled by SMB100A using USB
  • #6460: Driver: Prana MT400 amplifier
  • #6489: Check if the HI-6005 fieldprobe is working correctly in combination with the EPI1001A
  • #6625: Driver: Frankonia EFS-10 / EFS-100
  • #6641: Driver: Control the polarization on the antenna using an RadiCentre external relais card
  • #6662: Virtual Instrument for the field strength sensor
  • #6712: Switch the external 40 dB attenuator used with Keysight 33521B
  • #6777: Amplifier Linearity / Uniformity test different result at 1 -6 GHz
  • #6787: Agilent 4403B Spectrum analyser Device Not Connected error
  • #6863: Explanation for the use of correction factors for a Current sensor
  • #6864: DVDRSYS.DLL cannot be loaded anymore from new device drivers
  • #6886: Driver: Bonn Elektronik BLMA 4060-40
  • #6901: How to create a correction factor using the unit of transfer impedance in dBOhm
  • #6909: Why is a window with a description and value text is shown during the test?
RadiMation version 2015.3.4[edit]
  • #1151: Minimum performance level fixed field
  • #1881: Graphs for applicable signal/forward/reflected/net power need to be added if a related input is measured
  • #1945: Generated Power in Multiband immunity is not limited by the allowed range that is configured the AD Channel
  • #2869: Multiband test does not allow the user to select only the reflected power meter as an input
  • #3605: Multiband minimum performance is not possible
  • #4090: RI multiband minimum performance not working
  • #4576: Auto ranging of the HI422 is not working correctly
  • #4821: Driver: Tektronix 3000 for fixed voltage test
  • #4873: Wrong reading of TDS 3054B scope
  • #5323: Pre measurement detector suddenly turns other detectors on or off
  • #5572: Use maximum performance level as new start level at next frequency
  • #5880: Button to show overview of Calibration Expired (activated) devices
  • #6125: Possibility to set the used type of average detector
  • #6163: Configurable AD converter measurement always returns zero
  • #6233: Control the oscilloscope Tektronix TDS 2000 Series by USB
  • #6268: Specify CW instead of NONE, if no modulation is applied
  • #6385: Add report generator keyword which only outputs the date
  • #6631: Driver Polarization of the RadiField
  • #6640: Driver Configurable antenna tower device driver to control polarization
  • #6716: How to configure the increase of the power during regulation?
  • #6731: Allow that the available columns for the device driver can also be selected in the testsite configuration window
  • #6737: Driver RadiField 2003A/2006A/2003B/2006B
  • #6738: Windows 10 USB drivers for Radi-products
  • #6739: Hide the white area in the Virtual Instrument window
  • #6742: Agilent N9038A Average measurements taking longer than expected
  • #6762: Ability to select another detector in the R&S ESI powermeter
  • #6763: Using the R&S ESI 40 scanning receiver as a powermeter raises the error "BAND:MODE:FFT OFF"
  • #6764: Tektronix AFG 3252 Timeout while waiting for *OPC command
  • #6770: RadiField errors from the RadiCentre are not raised
  • #6771: RadiField Polarization driver should have 'ignore height change' ticked by default
  • #6774: R&S NRP-Z55 returns a -10000 dBm value when the powermeter returns a 'NaN'
  • #6779: How to perform a Radiated Immunity MB threshold level test
  • #6789: VSWR testlevel is not shown in the TestLevel inputs box
  • #6794: Multiple tests with same TSF name difficult to include in RG
  • #6801: Graph customization settings are not used during printout
  • #6806: A lot of 'Handles' are used by RadiMation
  • #6809: Can't find device driver for RadiField 1009B
  • #6812: Add new Reseller to the Sentinel Key program for Dongle programming
  • #6819: Tektronix TDS2024 is not correctly controlled
  • #6835: Can deleted measurements be recovered by RadiMation?
  • #6836: Is Windows 10 supported?
  • #6838: How to see more details of the tweeted improved RadiMation functionalities?
  • #6848: RPR3006W is not showing powermeter values when used as virtual instrument
  • #6858: RadiLog ReportError should include the RadiMation global event log of that process
  • #6867: Is it possible to add more than one amplifier to a test site?
  • #6881: Is the device driver for the R&S NRP-Z51 powermeter available?
RadiMation version 2015.3.3[edit]
  • #2550: Menu option that starts NI I/O Trace
  • #5091: Debugging of device drivers through DDLOGGER.DAT should be simplified
  • #5693: Driver: Agilent E7402A Spectrum Analyser
  • #6008: Possibility to temporarily disable system error checking in a device driver
  • #6119: Error that the frequency of an already used testsite is not suitable
  • #6384: How to use the R&S ESCI 7's built-in pre-amplifier in 30MHz-1Ghz range
  • #6400: Driver: IFI ST181-10 Amplifier
  • #6435: Is it possible to change a correction of an already performed MB emission test?
  • #6445: Keywords ||DATE MEASUREMENT|| and ||SETUP TYPE|| do not work anymore
  • #6447: Slow powermeter measurement of the R&S NRP Z91
  • #6533: PDF version of the RadiMation manual is 55 MB
  • #6551: Enables users to easily send Error Reports with RadiLog
  • #6553: Add RadiLog messages to the R&S NRPZ powermeter device driver
  • #6567: Include a menu entry in the main menu to start the RadiLog
  • #6597: R&S NRP-Z91 cannot be used in Powermeter Virtual Instrument
  • #6598: Checking a R&S NRP-Z91 takes forever when it is not connected
  • #6608: Add RadiLog messages to the USB HID device stream
  • #6653: Sending an error report causes an error report
  • #6655: Output parameters are not shown in RadiLog
  • #6658: Updating Error Report Window
  • #6659: Added button to ReportStauts error in RadiMation
  • #6666: Driver Teseq PMU 6006 powermeter
  • #6721: Not possible to measure the average field probe value during Multiband
  • #6722: RadiLog crashes with a 'startIndex cannot be larger than length of string'
  • #6778: More lines are included in the graph in a report than requested
  • #6784: “hot-key” to export the numbers from the harmonics + linear graph EUT-Calibration module
  • #6823: Do I need correction files in RadiMation for powermeters?
RadiMation version 2015.3.2[edit]
  • #1106: Directory names in the configuration should be shortened if they don't fit in the listview control
  • #2731: Address information of the customer, manufacturer and test-site should be able to be copied from or pasted to the clipboard
  • #2860: The amplifier control window is displaying nothing if no items are inserted
  • #4538: Turn during measurement explanation
  • #4805: Data export from menu REPORTS-EXPORT is not working
  • #5692: Driver: 3115 Double-Ridged Guide Antenna
  • #5877: Proceed to include some proposed wiki pages for inclusing in manual
  • #6071: Very slow band switching in Multiband Immunity (Levelling problem of Power Delivery Test)
  • #6277: The 'cancel' button should not be shown when an engineers is removed
  • #6283: Broadband units (like dBuV/m/MHz) are not possible for traces
  • #6438: Default frequency range of the EMCO / ETS-Lindgren antenna 3117
  • #6512: Use the Microsoft Visual Studio 2015 compiler
  • #6521: Amplifier Linearity test requires an antenna in the selected testsite for Conducted Immunity
  • #6546: New device drivers is raising Description for this error is not available error 536879923 during startup
  • #6548: Minimum supported Windows version should be changed to Windows 7 SP1
  • #6585: NRP Z55 zero operation took longer than 60 seconds error
  • #6588: RegisterDeviceDriver too slow. It takes a second.
  • #6605: Is the Ines USB-GPIB-2 card supported?
  • #6606: Is the Prologix GPIB convertor supported?
  • #6610: R&S ESRP 7: Not all bytes are written to the GPIB-Board
  • #6645: How can I set the resolution to logarithmic stepsize?
RadiMation version 2015.3.1[edit]
  • #3324: Linearity check for calibration (16 points, 5.1 dB down)
  • #4690: Language error: initialisation successfull <=> successful
  • #4772: Add a 'Pause' as a possible action
  • #5004: A warning should be shown if the AD-Channel maximum and minimum are the same
  • #5250: Change format of graph export per default
  • #5513: Directories configuration of latest version is interfering with older RadiMation version
  • #6168: Harmonic Graphlines have unlogical names
  • #6190: Add a general notification icon on all the Multiband configuration windows
  • #6193: Change the 'Change' button to 'edit' including a picture button.
  • #6196: The Version number in the shared Libs DLL's are not updated
  • #6197: Add a 'Remove' option in the right click menu of a device in the TestSite configuration window
  • #6201: The table with measurement data is not shown when the Harmonic test data is opened
  • #6242: Adding a 3rd amplifier to the amplifier control panel does not update the amplifier control panel correctly
  • #6292: Rename tabs on the testsite configuration: 'Standard 1' to 'Devices 1' and 'Standard 2' to 'Devices 2'
  • #6300: Enhanced Status Window parameters are not shown
  • #6326: Add more low baudrates: 1200, 600, 300, 50 Baud
  • #6335: 'Advanced Information' window should be renamed to 'General Information'
  • #6357: Regex returns 0 for notations with a space between +/- sign and the actuall number
  • #6401: Configurable Amplifier should have wait options after sending power on (for warming-up) and off (for cooling down)
  • #6408: Amplifier Slope verification for Conducted Immunity
  • #6455: Warnings related to wxEXPAND are shown when a wxWidgets dialog is shown
RadiMation version 2015.3.0[edit]
  • #5999: Mark the 'Continuous Measure' button in a different color when it is activated
  • #6295: When note window is opened the focus or cursor is not set to the text field by default
  • #6368: Duplicating more than 100 tests in a sequence takes a long time
  • #6369: Duplicating a test in a sequence file, doesn't mark the sequence file as changed
  • #6370: Radio buttons of Conducted Emission Manual Mode traces are swapped
  • #6387: It is not possible to select multiple peaks and therefore needs to select peaks one by one
  • #6388: Adding new peaks is resetting the peak lists selected column information
RadiMation version 2015.2.5[edit]
  • #470: No buttons present for often used operations
  • #510: No overview of of used equipment at start of a test
  • #940: Predefine which graphs should be shown on the screen
  • #3826: Show during measurement option in the graph line configuration window
  • #4162: automatically add and show the configured and selected ad channels in the graph window during an RI measurement
  • #4613: Calibration expire window should be a MDI client window
  • #4641: Switching between graph and table should rename graph button to table info
  • #5125: Closed loop measurements
  • #5527: Label of Show details button should become Hide details when details are shown
  • #5576: Driver: R&S OSP130 with option B102
  • #5607: Add "Save Calibration As..." possibility
  • #5661: Add Frequency range panel for Bonn BLWA drivers
  • #5678: Enhanced status window description of vertical and horizontal is not directly clear
  • #5985: ESR7 replies with error about AC_DC coupling on Channel2
  • #6020: Show all activated AD-channels by default in the graph during a test
  • #6027: Perform final measurements in EMI receiver mode with the Agilent MXE N9038A EMI receiver
  • #6036: Ability to enter manual information at each disturbance frequency
  • #6090: Start/stop time test fileds are not retained from 2014.2.12 to 2015.1.7
  • #6123: RadiMation is not responding when Amplifier Control window is enabled
  • #6270: Raise an error when R&S NRP-Z55 power sensor is disconnected during test
  • #6296: Device stream in the device driver system for http protocol using get and post
  • #6297: Driver: USB-xSPDT-A18 series switch matrix
  • #6299: R&S FSP30 spectrum analyser option for FFT filters
  • #6302: Driver: Tektronix RSA5100-series
  • #6321: Clear the input buffer of a configurable device driver directly after the connection is established
  • #6322: Not possible to specify the Escape character in the configurable device driver
  • #6323: Configurable switch matrix device driver sends the 'Turntable Changed' command before the turntable starts moving
  • #6337: Turning off Pre-amplifier option (INP:GAIN:STAT OFF) without this option being available is raising an error for the R&S FSV
  • #6340: No Unit is shown for test level
  • #6343: Ability to disable determination of the dynamic range during the Attenuation / Gain system calibration
  • #6345: Carrier Level command of the Configurable Signal generator is not transmitted if no Carrier On command is specified
  • #6349: Driver Switch matrix ICS 4864
  • #6354: QP Detector Measuretime of ESL6 is set to 10 ms
  • #6360: Driver: Tektronix 2001 for fixed voltage test
  • #6361: Ability to zoom in the frequency graph during the prescan phase of a MB Emission test
  • #6362: Frequency of the graph in the report is different
  • #6364: Too few spaces in the name of the graphline in a report generator code causes that the graph is not include in the report
  • #6389: Update the Configurable Switch Matrix wiki knowledgebase page
  • #6394: NI DAQ USB 6218 AD Converter default input min and max
  • #6395: NI DAQ USB 6218 AD Converter channels 9-16 can't be used
  • #6397: How to dirrectly reference from the Main Template to a Keyword for a certain test
  • #6398: Driver: Tektronix TDS2024C Oscilloscope
  • #6399: Driver: Tektronix AFG3252 Signal Generator
  • #6403: Ability to use the FSV-3 Analyser controlled as powermeter in zero span mode
  • #6405: ARFI7000 is not reading probe values
  • #6410: Driver: ETS-Lindgren 8000-053 amplifier
  • #6411: Driver: ETS-Lindgren 8000-034 amplifier
  • #6412: Raise an error when R&S NRP-Z55 is disconnected during a test
  • #6418: R&S FSV 40 Error -222: Data out of range DISP:TRAC:Y:RLEV -10 DBM
  • #6426: Configurable Switch Matrix isn't correctly saving settings when user configured commands of During and/or After Test are cleared
  • #6428: Device driver Check is erasing the selected correction file(s) in the device configuration screen
  • #6432: Device drivers that are using GPIBRS232 should be converted to panels
  • #6436: Selection of a correction file in a device driver configuration is not working
  • #6439: Driver: All ETS-Lindgren 8000-series amplifiers
  • #6442: What does the NRP settling time does?
  • #6448: Correct frequency range of the ETS-Lindgren 8000-034 amplifier
  • #6451: Frequency up / down for UFA calculation is not working
  • #6453: Uniform Field Area (UFA) calculation should trigger a default auto-layout when calibrations are added or removed
  • #6454: Not possible to use CAL files for the UFA when it contains different test distance
  • #6459: ETS-Lindgren 8000-053 Device Not Connected
  • #6462: How to set the RBW when the R&S FSP 40 is used as powermeter?
  • #6465: Driver: ETS-Lindgren Antenna series
  • #6467: Driver: R&S FSIQ 7
  • #6471: 'Decrement' should be the default value for the PowerStep setting of the Amplifier Linearity test
  • #6472: Settings that are normally protected for the administrator, can be changed when the dongle is not present
  • #6474: After zooming in a graph the graph axis is no longer linked to center and span
  • #6476: Save the configured Auto-Layout settings for the Uniform Field Area (UFA) calculation config
  • #6477: Insert Row in a Correction file is not working if no row is present
  • #6478: A new correction file should have 1 row by default
  • #6479: A new row should be added to a correction file when the 'TAB' key is pressed in the last cell
  • #6487: Driver: EUT Controller: Generic TCP/IP Status interface
  • #6488: Python program to test/verify the Generic TCP/IP Status inteface
  • #6491: Driver: Frankonia EMCL-20
  • #6493: GPIB address of Frankonia FC06 cannot be changed
  • #6504: Project: Remember which graphs should be shown
  • #6505: Propose best implementation to remember graphs to be shown
  • #6527: Ability to specify a frequency depending RBW for the R&S ESI Powermeter
  • #6536: Unit-test for the C++ CenterSpanStartStopFrequency class
  • #6537: In the testsite window, 'save as ...' should show the original name + ' - Copy' as the new suggested name
  • #6571: Remove Row of a correction file selects the first row if the last row was selected
  • #6572: Show a message with the used coupling value for the virtual coupler
  • #6577: Project: Telefication: Substitution measurement investigation
  • #6580: Showing the configuration window of R&S NRVS AD-Convertor crashes
  • #6586: ETS-Lindgren HI-4422 VI_ERROR_INV_PARAMETER: Invalid Parameter error
  • #6609: Update the splash screen logo of ETS to DARE!! Instruments
  • #6620: Driver: Frankonia ALX-4000E / AXL-80
  • #6624: Driver: Frankonia FLG-70C / FLH-200B1
  • #6627: Make StandardPreAmplifer device drivers Configurable
  • #6657: grid color always black
  • #6664: Driver: R&S ESRP7 as powermeter
  • #6717: Zero button should be shown for the FieldSensor Virtual Instrument
  • #6726: How do I configure the RPR3006W power meter for remote control?
  • #6735: Also show a magnifier button after the selection of the CONFDVDR directory
  • #6796: Report generator code to retrieve the 'Device driver versions'
  • #6847: General working and use of Main and test specific template with the Report Generator
RadiMation version 2015.2.4[edit]
  • #476: The CI configuration window is to small by default
  • #2216: ESD has strange behavior when pre defined report generation is enabled
  • #4498: Measuring settings Lines/Neutral with LISN
  • #4607: Customize graphs not working
  • #5322: Signal Generator setting the frequency raised an error
  • #5954: R&S ESL 6 Scanning Receiver Specific System Error -222 Data out of range SCAN1:TIME 1 MS
  • #6152: Incorrect behaviour of Save button after RE test
  • #6287: Driver: R&S ESL6 as Sensor power meter
  • #6301: Preamplifier setting is not visible anymore in the CE MB TSF window
  • #6303: HP 34401A message There is no Device Stream Configuration
  • #6303: List of performed tests is not updated in the report generator, when a test is finished
  • #6308: COM port setting is not remembered in the RadiMate IV device driver
  • #6314: Is it possible to use mutlimeters or oscilloscopes for conducted immunity tests
  • #6372: Can I take an existing graph / plot and generate an excel file with the frequency and amplitude data?
  • #6793: How can the settings of an oscilloscope for the the Voltage measurement during a Conducted Immunity be set?
RadiMation version 2015.2.3[edit]
  • #1864: Move during measurement checkbox is shown in unlogical state if multiple bands are selected.
  • #5320: Folder name is changed to New Directory again
  • #5744: After adding a TSF directory it doesn't show the renamed directory name directly
  • #5894: DARE Homepage menu item name and link is incorrect
  • #5898: Graph items and restore factory default are disabled for the Chart settings
  • #5947: Modulation of Marconi 2024 Signal generator is never turned off during CI test
  • #6202: Show the DeviceStream configuration of a device driver in a panel below a combobox
  • #6243: Communication issue with a RadiSense IV connected by CTR1
  • #6250: Advanced configuration dropdown boxes are not visible for the RadiSense IV driver
  • #6286: Report generation doesn't replace all the codes
  • #6289: CompleteBuild.py is not triggering a rebuild
  • #6309: How to configure test setup files when using a low resolution?
RadiMation version 2015.2.2[edit]
  • #703: Calibration Types
  • #1922: No compression information in table form when performing a Compression test.
  • #1923: No color difference in graph at Compression test
  • #2288: Automated test for EFT
  • #2289: Automated test for Surge
  • #3812: EFT and Surge do not have seperate positive and negative pulse levels
  • #5269: Frequency is not set during harmonic measurement
  • #5285: Harmonics measurement (amplifier cal) is not working
  • #5574: Harmonics measurement could be optimistic
  • #5614: It is possible to start a test without an EUT opened
  • #5737: EFT test duration field is required
  • #5902: Not possible to remove test specific report generator template from items in the report generator settings list
  • #5903: List sorting settings of the Report Generator Settings are not retained
  • #6100: Device driver: Teseq NSG3040
  • #6122: Common buttons on the Multiband status test window should be enabled
  • #6129: Device driver: emtest EFT 500M
  • #6132: Sequence number in PI MB EFT test is not updated
  • #6137: Update list of available EFT-line couplings
  • #6138: Update list of available Surge line couplings
  • #6139: Driver: Haefely PEFT-Junior
  • #6140: Selected Cable in EFT & Surge MB test is retained after it doesn't exists anymore
  • #6141: Driver: GPIB support for emtest UCS500N
  • #6144: Update the progress column of the EFT and Surge tests
  • #6145: Implement the test repeat count for EFT and Surge tests
  • #6146: Is Random Surge angle working correctly?
  • #6148: Creating a new EFT MB TSF shows an empty screen
  • #6164: Enable Amplifier harmonics and gain for all users with the Immunity module
  • #6179: Units are not correctly shown initially in the BandsGrid control
  • #6180: Only the duplicates bands should be selected after duplication in the BandsGrid control
  • #6181: Up and down buttons of the BandsGrid control are flickering during changes
  • #6182: Up and Down buttons in the BandsGrid control are swapped
  • #6192: Move the 'Change' button of the units to the bottom right of the units
RadiMation version 2015.2.1[edit]
  • #4354: Test data graph has become black
  • #4398: Graphs (auto) scaling is not functioning as expected
  • #4811: When start frequency is unchanged it's causing frequency range errors
  • #5001: Allow to insert attachments in an EUT file
  • #5002: Possibility to directly attach generated report to the EUT file
  • #5524: File is probably corrupt, or it is created with a newer version of the software
  • #5682: Tolerances of AD Channel are shifted after report generation
  • #6015: Is it possible to perform the power delivery test on another frequency
RadiMation version 2015.1.12[edit]
  • #3821: Test equipment not correctly changed in radiated immunity multiband
  • #5402: Driver: AR 20ST1G18 Amplifier
  • #5595: Driver R&S Vector Signal Generator SMBV100A
  • #5596: Driver: AR 50ST1G18 amplifier
  • #5670: How to integrate probe calibration values into RadiMation
  • #5871: Metrohm Antenna Tower device driver
  • #5892: Turning on modulation of R&S SME is having a hardware delay
  • #6033: Extend driver for Agilent 34401A Multimeter (AD Converter) with VISA communication
  • #6063: HP 4417A Power meter issue
  • #6136: Driver Frankonia controller Model FC-06
  • #6200: The AD Channel configuration window is not responsive when it is shown the first time
  • #6208: Driver: IFR2398 Spectrum Analyser
  • #6209: Configuration National Instruments AD converter for channel 9 and higher
  • #6211: HI 6105 Device Driver Function Not Implemented
  • #6212: HI 6105 wxDynamicLibrary already loaded error
  • #6213: HI 6105 always tries to switch to local
  • #6214: Driver Prana DP600 amplifier
  • #6221: Driver Anritsu Spectrum Master MS2713E as field sensor for 2000-1791-R antenna
  • #6222: How can we change the speed of the Maturo turntable
  • #6224: Extend driver for Agilent 34401A AD Converter with VISA communication
  • #6225: Driver Manual Controlled AD Converter
  • #6226: No values for National Instruments AD converter channel 9 and higher
  • #6232: How to measure the Frequency and duty cycle with Oscilloscope or AD Converter
  • #6234: Directly raise an error when device is disconnected
  • #6249: Wrong AD Channel is selected for RadiSense probe
  • #6272: Driver of Keysight Technologies N9038A is checking for the 'Agilent Technologies' *IDN? response
RadiMation version 2015.1.11[edit]
  • #1491: The directory selection is not showing the directory
  • #2697: Possibility to use units during editing of correction files
  • #5683: Driver EPI1001A CTR plugin card
  • #5971: Driver: Fluke45 as multimeter
  • #6098: Logarithmic step frequency for R&S ESPC Receiver
  • #6151: Advantest R4131D No match was found in the specified regular expression errors
  • #6161: Graph Customization Configuration button Restore factory default is always disabled
  • #6166: Verification TESEQ drivers
  • #6169: RPR device driver is crashing RadiMation
  • #6173: First sweeps Advantest TR4172 are jittering, causing wrong measurement results
RadiMation version 2015.1.10[edit]
  • #3503: The configurable signal generator does not allow the setting of the external modulation settings
  • #4410: Changed modulation settings are not applied
  • #4831: Not possible to see actual values in table mode
  • #5467: Hide all table information is not working
  • #5782: ESRP raises an error for an unknown header: INP:GAIN:LNA:STAT OFF
  • #5796: Setting the frequency is showing rounding issues
  • #5915: Driver: Keithley Arbitary Generator 3390 as modulation source
  • #5960: Pulse modulation settings in the singleband fixed power manual mode window are not forwarded to the signal generator device driver
  • #6054: Cross thread operation detected error
  • #6057: Keyword ||RADIMATION VERSION|| is exporting 201x,x instead of 201x.x.x
  • #6061: Can not save LLF anymore after making changes
  • #6065: Multiband PM Modulation Configuration setting is not retained
  • #6066: Windows Universal Naming Convention (UNC) is causing error "Access to the path.. is denied." when creating a new TSF directory
  • #6078: Opening a test in a newer version overwrite test data used RadiMation version
  • #6085: Support 2 Hz AM modulation in RadiGen
  • #6095: Driver Bonn BTA 0122-3000
  • #6099: RadiCentre is still in remote after deinitialisation
  • #6102: Overshoot detection of the EMCO1060 is not working
  • #6103: Suggested product id number for instrument descriptor of NRP power meters is wrong
  • #6107: R&S BBA100 RF path is not being switched between bands
  • #6111: R&S AFG device check seems to be always successful
  • #6112: R&S BBA100 RF option to always keep amplifier on
  • #6113: External Modulation Source settings are lost
  • #6114: Configurable Signal Generator Modulation settings are not retained
  • #6115: Enable wxWS_EX_VALIDATE_RECURSIVELY for all device drivers
  • #6116: Move during measurement should not be visible in an immunity multiband test
  • #6120: Configurable Modulation Source carrier level is not send
  • #6171: CARAD EUT Controller driver settings are not retained
RadiMation version 2015.1.9[edit]
  • #4140: Problem with ESL6 and conducted emission LISN test
  • #5140: Current Status windows without a description is shown
  • #5230: Not possible to delete measurement data from the EUT
  • #5325: R&S ESIB26 Analyser not all bytes are writen (..) within the timeout period
  • #5526: Implement Word Wrap for error code descriptions
  • #5889: CDN test according EN61000-4-6
  • #5891: Driver National Instruments AD converter (NI USB 6218 BNC)
  • #5929: Monitoring input channel setup is not using the correct default device driver setting
  • #5943: AR No Listeners are detected on the GPIB bus and the KRE matrixes is alway switching to position 2
  • #6060: Quasi peak measurement of Advantest TR4172 sometimes has a difference
  • #6067: Agilent N9038A MXE is not using Discrete Scan Type
  • #6072: Driver Narda SRM3006
  • #6082: Typo in the description "successfull"
  • #6083: Adding beeb as before or after action is directly showing a warning
  • #6084: Driver AR 100S1G6 amplifier
  • #6091: How to manually operate an Antenna Tower and Turn Table
  • #6097: How to perform a CE measurement with a voltage probe (PMM SHC-1-1000)
RadiMation version 2015.1.8[edit]
  • #5052: Reference level is changed during measurement, generating an IF overload
  • #5385: Power delivery test stops with “Power went to high -4dBm Signal Power"
  • #5829: Frequencies labels are not correctly updated in a Mutiband TSF
  • #5950: Driver Amplifier Bonn BSA 0106
  • #5976: Saving a Pause Test is generating several 'file corrupt' problems
  • #5983: Driver for obsolete field probe PMM8052
  • #5998: What means: 'before', 'during' and 'after' on the EUT Monitoring channel
  • #6002: Do not change the reference level. Leave it fixed on the selected level
  • #6030: AR FP 3000A Field sensor is not connected
  • #6034: New EUT Monitoring channel configuration is not working in Singleband immunity
  • #6035: Values specified in the Min and Max of AD Input Range are lost
  • #6037: Driver National Instruments Switch (NI USB 6218 BNC)
  • #6038: Driver HP 83650A Signal generator
  • #6039: Driver FSP 40 as powermeter
  • #6040: Driver CBL 6112C
  • #6043: Units configuration is not applied to test
  • #6045: Auto save function after completion of (Multiband) tests is polluting the EUT
  • #6051: Possibility to send switch command before power on for the Configurable Amplifier device driver
  • #6052: Configurable amplifier device driver is sending the standby command at start of test and operate command after the test
  • #6056: Monitoring input channels from channel 33 and higher are not working
  • #6079: Problems with Software Protection Key dongle
  • #6089: No graph or table information is exported in manual mode test data
  • #6092: Different antenna polarization errors during UFA calculation
RadiMation version 2015.1.7[edit]
  • #2140: Ampersand in name of test-site is shown as underscore on information window
  • #5634: R&S ESPI 7 specific system error SWE:SPAC LIN
  • #5856: Auto move of antenna tower is harmfull for hardware
  • #5904: Keyword TEST TIME is exporting wrong data and shows TEST START TIME
  • #5906: Spurious emissions with high values are detected during noise floor measurement
  • #5910: Sunol SC110V customer specific Antenna Tower driver
  • #5917: Final peak measurement with ESR 7 blocks the software
  • #5925: Configurable Signal Generator is missing the Remote Control checkbox
  • #5939: Strange measurements with the R&S ESVS20 Test Receiver
  • #5940: HP 33120 signal generator raises error 1 -113
  • #5946: Driver AR 40S4G18M4 Amplifier
  • #5961: A 1 hour multiband immunity test causes an algorithmic calculation error
  • #5964: R&S ESR7 Specific System Error -141 Invalid character data SWE:SPAC APUL
  • #5970: RSS1006A no connection after changing COM port
  • #5980: The entry "Configurable EUT Controller" is in the driver list of Switch Matrix and not in the list of "EUT Controllers"
  • #5986: Frequency up/down is not working in multiband immunity manual mode
  • #5987: Driver Milmega AS0827-55 amplifier for IEC61000-4-3
  • #6014: Power delivery test is not succesfull at 550 MHz
  • #6044: How can I get more precision from the data of a calibration file?
  • #6074: Forward power measurements values are showing dips
RadiMation version 2015.1.6[edit]
  • #4598: Driver PMM9010F
  • #4947: Diagram description in dBuA/m with Magnetic field setting
  • #5155: Driver PMM9010F
  • #5369: RadiMation crashes when SRQ line is busy
  • #5594: Driver Agilent Power Meters U2000H, U2000B and U2002A
  • #5641: Signal power went to high errors with Gigatronic 8542C powermeter
  • #5645: Peak measurements give different results
  • #5841: MXE receiver N9038 is not starting performing the measurement
  • #5843: First point of forward powermeter (Advantest analyser) measurement is wrong
  • #5844: Advantest analyser as powermeter is not automatically switching the attenuator
  • #5847: RadiField field verification
  • #5883: ESL 6 quasi-peak measurement gets stuck
  • #5907: Error detected during the start of the sweep with PMM 9010 F
  • #5919: Unexpected power readings with RPR3006W Powermeter
  • #5932: RIGOL DSA 815 AVG and QP measurements are showing differences compared to manual measurements
  • #5933: Regulation in the Multiband Immunity test is not increasing the power to satisfy both Testlevels
  • #5937: Driver: Rigol DSG3060
  • #5945: RIGOL DSA 815 timeout and query interrupted
  • #5948: When opening test data a Run-time error '91' Object variable or With block variable not set is shown
  • #5949: Driver AR Field Analyser 7006 read out
  • #5951: RadiMation crash during startup
  • #5955: Drivers AR DC2500AM1, DC7128A, DC7420M1, DC7530 and DC 7620
  • #5957: Driver AR 40T26G40A
  • #5958: Drivers Antennas ATEK30MM1, ATL80M1G, ATH18G27, ATH26G40
  • #5965: What is the difference between the average value and the measurement value of the used field probe?
  • #5966: Why is the setting of the frequency range missing in the driver window?
  • #5972: When is the CAL calibration file needed to be used
  • #5979: What is the External Dwell Time and how is it working?
RadiMation version 2015.1.5[edit]
  • #3864: Init of the multiband test is not using the amplifier driver of the amplifier manager
  • #5590: Include option to download latest drivers.exe in RadiMation setup program
  • #5602: Include option to overrule drivers.exe included in RadiMation setup program
  • #5826: Error 76: Could not find a part of the path (..)
  • #5828: Opening a TSF file from a sequence is suddenly changing focus at the sequence window again
  • #5830: Test file is corrupted after opening and saving
  • #5831: Unexpected forward- and sensor power measurements during calibration
  • #5896: Showing graph and table information is making the performed test extremely slow
  • #5909: Configuration of Narrow band / broad band detection according to standards has disappeared
  • #5922: Update Copyright information of device drivers setup
  • #5928: Current Closed loop method is not correctly controlling/reading the sensor power meter
  • #5931: Data files of a RI Multiband test are corrupted after editing the note
  • #5959: Driver: Narda PMM EP408 Field probe
RadiMation version 2015.1.4[edit]
  • #2249: Not possible to set limit line from 500 Hz to 900 Hz
  • #4019: Unexpected CIC errors
  • #4733: No trace of the measurement data visible
  • #4748: QP measurements seems to be wrong
  • #5406: Peaks are detected outside the graph trace
  • #5563: Continuously measuring envelope power of the RadiPower results in memory problems
  • #5684: Unexpected high noise floor with CXA 9000A
  • #5818: Driver for R&S ESPC not working anymore after updating drivers.exe
  • #5821: VI Powermeter: Burst Graph doesn't show the graph by default
  • #5823: Driver: Teseq NSG 4070 as Amplifier and Powermeters
  • #5827: TSF files can't be deleted, delete and Ok buttons are always disabled
  • #5837: How can the field sensor be corrected by a RadiMation file?
  • #5846: R&S ESRP error Data out of range during time setting
  • #5848: Does the modulation needs to be turned off and on during each frequency step?
  • #5849: How can a customized warning message be shown?
  • #5857: GPIB Hibernated NI Drivers error required PC restart and loss of data
  • #5860: Frequency range of Agilent N5171B Signal Generator
  • #5862: How to add the correction for the emission antenna VW TL81000?
  • #5868: RadiMation is crashing when device is not connected
RadiMation version 2015.1.3[edit]
  • #5642: Driver Teseq NSG 4070 as Signal Generator
  • #5736: No trace data obtained from measurements with FSV13
  • #5739: Cursor information is no longer shown
  • #5778: Rigol spectrum analyser as powermeter is using pre-amp
  • #5780: Control of the Maturo antenna tower is not working if it is controlled with a LAN-to-GPIB convertor
  • #5790: Final measurement of QP detector on R&S ESI always returns 0 dBuV
  • #5797: R&S SME03 Specific system errors Level over range and ALC failure
  • #5800: Windows XP is not supported anymore
  • #5801: Detection if zeroing of RadiSense4 probe is finished takes a long time
  • #5803: Controls of the VI Powermeter are not reenabled if the auto-trigger is disabled during the re-trigger wait time
  • #5805: Old test results cannot be loaded in 2015.1.2
  • #5816: Rigol spectrum analyser pre-amp settings can't be controlled
RadiMation version 2015.1.2[edit]
  • #5787: Selection of another TSF folder doesn't update the list of TSF's in that folder
  • #5791: Uniform Field Area Calculation is not working for Constant Power method calibration files
RadiMation version 2015.1.1[edit]
  • #5775: Driver R&S switch matrix for amplifier BBA100 interlocks
Known Problems[edit]
  1. Open the configuration window of RadiMation®
  2. Select the Device Drivers tab
  3. Select Receivers/Spectrum Analysers
  4. Select the R&S receiver
  5. Press Edit to open the device driver configuration window
  6. Press the Advanced button
    • The GPIB configuration dialog of the R&S device driver will be shown
  7. Activate the Show advanced Settings checkbox
    • The GPIB Configuration dialog will show a Wait time box
  8. Specify 3000 us in the Wait time box
  9. Close all windows, and repeat these steps for each and every R&S receiver.
