Release Notes 2020.2
We are proud to deliver you Version 2020.2 of our RadiMation® EMC Test software. This 2020.2 version is the result of several major improvements that we have done.
This letter contains all the information that is needed before your system is upgraded. If you have any additional questions or remarks please let us know through your reseller, or contact radimation-support@raditeq.com.
Installation[edit]
Backup[edit]
When a RadiMation® file is opened, changed and saved in a newer version of RadiMation®, it is possible that it will be saved in a newer file format, which cannot be opened anymore in an older version of RadiMation®. To prevent that changed TSF, LLF, COR, SEQ or EUT files cannot be opened anymore in an older RadiMation® version, we strongly recommend to make a backup of the directories that contain those files. Before you install the latest version of RadiMation®, please make sure to safeguard all your critical data.
Make a back up of (at least) the following directories:
- Correction files
- TSF files
- Sequence files
- Limit Line files
Information on how to create a backup is available in RadiMation Application Note 152: Creating back-ups and restoring important RadiMation files.
Be advised that:
Installation[edit]
Updating device drivers[edit]
Solved items[edit]
See below the list of all the issues that have been solved in RadiMation® version 2020.2 since version 2020.0
RadiMation version 2020.2.10[edit]
- #11479: Are Limit lines auto-included when exporting graphs using the report generator
- #11500: Driver: LadyBug LB480A
- #11633: Driver: Raditeq RPR3008W.
- #11640: Adjust raditeq IDN queries for raditeq devices
- #11653: Error 10 while controlling the old model of the EM-Test CWS 500
RadiMation version 2020.2.9[edit]
- #5282: Strange message for HP 8903A + 8903B (Motorola).
- #10091: Wrong start frequency/StartFrequency changed
- #11483: ErrorReport: "RBW fouten tijdens na meten pieken!!!!"
- #11605: Configurable LISN with manual messages, shows the messages too often
- #11606: Reference level of the Tektronix RSA507A is not correctly set at the begin of the test
- #11607: Attenuator of the Tektronix RSA507A is not correctly set at the begin of the test
- #11608: Change in reference level adjusts the top of the graph in Tektronix SignalVU, reference level itself is not changed
- #11609: Progress calculation of trace retrieval from Tektronix SignalVU stays on 0%
- #11611: R&S ESRP measures first average detector final measurement with different RBW
- #11613: Rigol RSA5065A retrieves trace before sweep is finished
- #11615: ErrorReport: "Wrong data in Peak Table at QP measurement"
- #11616: Boonton 9241 in 4230 emulation mode cannot be controlled by Boonton 4230 driver
- #11620: ErrorReport: "MK Messtechnik Motion detection"
- #11623: AMETEK CTS: Issue 2021-03-01_Angle and Height in Peaktable wrong
RadiMation version 2020.2.8[edit]
- #8300: R&S ESPI Scanning Receiver Specific System Error -200 Execution error; Function not available; SCAN1:BAND:RES 120 KHZ
- #9548: R&S ESL 6 Scanning Receiver: Specific System Error: -200,"Execution error; Function not available; BAND 120 KHZ"
- #9552: ErrorReport: "R&S ESL 6 Scanning Receiver: Specific System Error: -200,"Execution error; Function not available; BAND 9 KHZ""
- #9962: R&S ESL 6 Scanning Receiver: Specific System Error: -200,"Execution error;Function not available;BAND 9 KHZ"
- #10292: R&S ESL 6 Scanning Receiver: Specific System Error: -200,"Execution error; Function not available; BAND 120 KHZ"
- #10902: Radilog: Unable to open file, file does not exist
- #10920: Issue 2020-04-09 AL1_ in Word export File QP Markers are connected with a line
- #11078: Error when using Quasi-Peak detection with 120 kHz RBW on a R&S ESL6
- #11170: Driver: Yokogawa FG420.
- #11216: Test receiver ESL 6 (9kHz-6GHz): Specific System Error: -200,"Execution error; Function not available; BAND 9 KHZ"
- #11403: Driver: Tektronix RSA507A
- #11446: Indication of Modulation in Multiband Immunity.
- #11450: Rohde & Schwarz FSL 6: Specific System Error: -222,"Data out of range; INP:ATT 50 DB".
- #11457: Time based ramp up is not linearly increasing.
- #11458: Settings the test state in EFT/Surge Manual does not correctly progress the test state
- #11459: Specifying a ramp-down or ramp-up with 0.1 dB accuracy is not remembered
- #11471: Report Generator output file extension is not automaticly matched with the template extension
- #11479: Are Limit lines auto-included when exporting graphs using the report generator.
- #11482: ErrorReport: "Client information is not stored in EUT file"
- #11497: graph->customization->(chart)scaling button selection is not behaving correctly
- #11498: Driver: Teseq RFB 2000
- #11502: Driver: R&S HP907
- #11517: Text in EUT-overview is disappearing
- #11519: Font 'Quicksand' does not support style 'Regular' on a Windows 7 SP1 PC.
- #11521: UFA Calibration table does not show all data.
- #11526: ErrorReport: "The software freezes or locks up after measure" with a PMM9010
- #11529: Change the tab order in RI and RE.
- #11532: RPR3006W #010 (8GHz).
- #11535: Inn-Co CO 3000 (Unit 1): Syntax is sent when an invalid command is received.
- #11541: e-mail address shown on about window is incorrect.
- #11542: Conducted emission multiband status window doesn't resize the content in the height.
- #11543: EFT surge kan geen andere spanningen dan 1, 2, 5, 10 kV
- #11547: ErrorReport: "Unable to create a database link"
- #11548: Wavecontrol SMP2: "External component has thrown an exception."
- #11549: ErrorReport: "Bands graph not full after reseizing TSF settings"
- #11551: Entering high values(as user input) for Ri & Ci in PI Surge manual mode triggers an stackoverflow exception
- #11552: PI bands Copy&duplicate buttons size
- #11558: Provided frequency is too high: DARE.RadiMat.FrequencyMHz MHz.
- #11562: Pulsed immunity surge test: index was out of range.
- #11564: Table on the radiated emission manual mode window is drawn outside the visual area.
- #11567: Full screen graph is not scaling in Radiated Emission Multiband.
- #11571: Driver: Prana N-MT 250D
- #11573: ErrorReport: "Limit lines are gone if I sellect all 3 freq. bands"
- #11575: Crash when an unexpected GPIB EDVR is detected
- #11579: ErrorReport: "No status visible of carrier and modulation"
- #11582: Reduce general tabs icon size.
- #11585: Showing the About screen from the menu, will crash the software.
- #11586: ErrorReport: "GPIB lock error"
- #11591: ErrorReport: "Moving antenna als er niet gemoved moet worden"
- #11595: Where did the general info button go to?
- #11621: How to apply correction of van Veen loop?
RadiMation version 2020.2.7[edit]
- #8377: Conducted Immunity CS not able to execute in MB test error Illegal Conducted Immunity Calibration File
- #10434: HP 34401A always uses the DC V setting Instead of AC V and therefore we are not able to calibrate
- #10436: HP 34401A MultiMeter - By default select AC Coupling
- #10819: Change default name of installation directory
- #10920: In Word export File QP Markers are connected with a line
- #10960: You are not allowed to edit this selection because it is protected.
- #11133: HP 34401A cannot be used in AC mode
- #11205: ErrorReport: "No voltage level indication available in CI-MB
- #11212: Graph customization configuration shows dB(m) as unit instead of dB
- #11284: "No current level indication available in CI-MB
- #11286: Change email adres in language files.
- #11326: CI - CS101 - SB - Power is not limited to value stored in Calibration file
- #11330: Report generator data inserted in wrong columns
- #11338: RadiMation does not reset previous shown sub-windows when restarted on dual monitor systems
- #11344: Unclear message: 'Connect powermeter to reference' during amplifier compression system calibration
- #11346: ErrorReport: "Collection was modified; enumeration operation may not execute."
- #11360: ErrorReport: "Signal power went too high (-6 dBm) during power delivery test"
- #11377: ErrorReport: "Object reference not set to an instance of an object."
- #11385: Better error description for The factory for the persistable object is not registered
- #11389: ErrorReport: "Object reference not set to an instance of an object.", when calculating the UFA
- #11390: Error code from RadiSense IV is reported as another error
- #11410: Adjust form "Test Engineer" to use the notification control.
- #11415: Using edit button EUT Information is not doing anything
- #11417: ErrorReport: "Input string was not in a correct format."
- #11431: Anchoring and resizing of frmSequence.cs
- #11437: "incorrect pass/fail statement on EUT overview page"
- #11439: Cannot update drivers for Raditeq RadiMation
- #11440: Cannot change language in 2020.2.6.
- #11443: Rohde & Schwarz FSL 6: Specific System Error: -148,"Character data not allowed; INP:COUP AC".
- #11444: Driver: RS1860B stick probe.
- #11449: ErrorReport: "Keyboard functions not working when browsing for EUT file"
- #11452: Report generator issues (graph not included + unit text missing in description)
- #11453: Report generator does not include column: Peak Value
- #11460: Treeview selection control on graph export is not correctly sized.
- #11472: Include correct dialogs dll in setup.
- #11475: Units are not visible behind start frequency.
- #11481: Functionality to include the AD-channels as a table in generated reports
- #11485: Column ‘selected’ with text ‘true’, when no final peaks are measured.
- #11515: R&S FSU raises error when Preamplifier is used above 3.6 GHz
- #11520: How to add additional cal kits in RadiMation
- #11533: Test receiver ESL 6 (9kHz-6GHz): Specific System Error: -200,"Execution error; Function not available; BAND 120 KHZ".
- #11596: XAL: How to improve "overall" measurement time!
RadiMation version 2020.2.6[edit]
- #4170: Report generator ability export table cells without unit
- #10852: Error -2147024893 after initial installation
- #11000: Cannot find field probe 0 in the currently active testsite.
- #11168: Driver: Ametek CIP 9136A.
- #11171: Driver: BONN Elektronik BDC 1060-20/200.
- #11172: Driver: Schwarzbeck HA9251-48.
- #11180: Driver: BONN Elektronik BSA0140-250.
- #11181: Driver: BONN Elektronik BLWA2010-400.
- #11182: Driver: Ametek CBA 1G-1000.
- #11183: Driver: Ametek CBA 3G-450.
- #11231: ErrorReport: "Error Virtual device and then out of memory error after second run of LISN test: "
- #11247: Version number that is included in the ErrorReport e-mail has 4 parts instead of normally communicated 3 parts
- #11303: Report generator keywords for impedance are not described in the manual
- #11305: Opening >1 LLF from explorer having RadiMation closed will lock the file.
- #11311: Table of content starts at level 4
- #11324: Logarithmic value interpolation is not working
- #11400: Buttons in PI- EFT are not according to GUI guidlines.
- #11407: Configure button standards, icons are missing.
- #11408: Move save as button in Test equipment screen.
- #11409: Make it possible to show delete or remove in the ctlAddEditRemove control
- #11413: Duplicate button is not perfectly aligned, as it is placed slightly lower than the other buttons
- #11442: Driver: RS2018B probe.
RadiMation version 2020.2.5[edit]
- #10788: R&S ESU26: Receiver (ID1465) Input 1 (LAN): More points received from the receiver/analyzer then calculated.
- #11249: problem with generating logarithmic step from immunity testing in report
- #11289: RI MB TSF cause crash.
- #11381: Embedded font warning when opening pdf manual
RadiMation version 2020.2.4[edit]
- #10681: convert main menu to the DevExpress XtraRibbon
- #10682: Build dynamic devices menu in XtraRibbon
- #10683: Build dynamic testsite menu in DevExpress XtraRibbon
- #10861: Add a 'Configure' button on the Standard selection dialog.
RadiMation version 2020.2.3[edit]
- #10708: Put controls that are directly on a form in a panel
- #10722: Retrieve gray-scaled pictures to be included on buttons
- #10723: Change colored pictures to gray-scaled pictures
- #10975: Data of S-Parameter measurement is not shown anymore
- #11012: Icons for the correction file selection on the device driver configuration are huge
- #11029: Object reference error when a new heliview antenna diagram location is created
- #11030: Value cannot be null, when specifying the address of the Heliview location
- #11031: Smallest window size of Heliview Integrity test is not correct
- #11032: Starting the Heliview integrity test crashes RadiMation
- #11160: When 'measure during turn' is activated without a turntable in the testsite, the tests stops very fast without warning
RadiMation version 2020.2.2[edit]
- #10706: About window dynamic version number update.
- #10707: Replace all controls on all windows.
- #10709: Replace the icon on all the windows.
- #10712: Update windows and controls in the shared libraries.
- #10713: Replace all popup menus to use the DevExpress popup menu.
- #10848: InvalidArgument=Value of '0' is not valid for 'DropDownHeight'.
- #10853: Scrolling in screenshot image of error report is not possible anymore.
- #10856: Oldest line of the eventlog is selected.
- #10857: Customize button on the Graphs tab of the configuration dialog is partially hidden.
- #10862: Two different languages are marked as '(Current)'.
- #10864: Company logo of the reseller is not shown anymore.
- #10873: Object reference error.
- #10882: Activate DirectX support on the skinned version.
- #10893: The date picker is no longer available.
RadiMation version 2020.2.1[edit]
- #10684: Shorten the menu entries in the (main) menu
- #10711: update darelang to accept devexpress controls
- #10750: Ampersands are shown in the new ribbon menu
- #10835: Could not load file or assembly 'DevExpress.Dialogs.v19.2.Core
- #10881: One-tabpage tabcontrols to show as a border have a TabStop
RadiMation version 2020.1.9[edit]
- #10653: LAN Controlled INN-CO CO3000: Always error during deinitialization
- #10688: Teseq NSG 4070-35: RS232: The rs232 runtime data is not created
- #10879: No error is raised when the RadiGen is controlled while the interlock is not closed.
- #10905: 1GHz: Attenuation set too high
- #10996: Error message from the Inn-CO CO3000 during deinitialization of the test
- #11161: Transient3000: How to setup the dip angle.
- #11162: Transient3000: How to setup the reduced voltage time.
- #11184: "DARE!! Instruments RGN6000B: Device returned Error code : 4005".
- #11186: Exported average values are wrong.
- #11187: Values are exported in linear scale but are expected as dB values.
- #11259: Driver: Keysight Technologies DSOX3014T
- #11272: Driver: Keysight Technologies N9048B
Radimation version 2020.1.8[edit]
- #10466: FCU 3.0 s: Change the unit labes to reflect the different LD types
- #10469: FCU 3.0 s: Make a equipment page and add information to setup in Radimation
- #11126: Frequency points are not included in export of limit lines
- #11146: The tabs with Peaks, Events and Notes on a Multiband window are not enlarged to the window size
- #11148: Maturo FCU3.0 controlled turntable is not starting with turning
- #11150: Current measurement is always measuring 500 mA.
- #11154: Order of tabs shown on ctlControlGeneralTabs for Immunity and Emission
- #11206: Exporting data of multiple bands as seperate graphs
RadiMation version 2020.1.7[edit]
- #9486: Project: HV/LV transfer measurements.
RadiMation Version 2020.1.6[edit]
- #8673: Printout shows incorrect RadiMation version.
- #11102: Out of memory exception when exporting more than 8 test files with the commandline interface.
- #11122: System.ArgumentException in clsDocViewController.GetVisibleForms().
- #11129: A very high header is used on the printouts
RadiMation version 2020.1.5[edit]
- #8833: Default value of tolerance in fixed field test is 0.0 dB, which results in very long test time.
- #10593: Order columns is changed when exporting to excel
- #11020: Add radilog error messages for empty exception catches.
- #11086: PowerDelivery Enabled setting in TUNING.INI is modified when the CONFDVDR directory is changed
RadiMation version 2020.1.4[edit]
- #11080: radicli.exe generatereport does not output all data.
RadiMation version 2020.1.3[edit]
- #5337: Partly protection of TSF files.
- #8814: Default value of the electrical field strength is too low.
- #10252: Also include a graph for the measured impedance in the Network Analyzer EUT calibration.
- #10825: RadiMation Emission Burst: When setting trigger to auto then you can't stop the test.
- #10931: Error: Access to the path 'C:\TUNING.INI' is denied.
- #10937: Zero the field probe when the field sensor is used as an AD Convertor.
RadiMation version 2020.1.2[edit]
- #7619: Filename should be shown in the window title before the program name.
- #9481: Perform the generation of a report from the command line.
- #10617: Analyser set to wrong frequency.
- #10684: Shorten the menu entries in the (main) menu.
- #10843: Object reference not set to an instance of an object.
- #10881: One-tabpage tabcontrols to show as a border have a TabStop.
RadiMation version 2020.1.1[edit]
- #10181: RSRESW8 - Receiver (ID1703) Input 1 [LAN]: More points received from the receiver/analyzer then calculated.
- #10647: ErrorReport: "DARE!! Instruments RGN2400A: The requested carrier level is higher than the maximum ( 13 dBm). Limited the set carrier level to 13 dBm. "
- #10648: Include the RadiMation version number in the text of the e-mail of the error-report
- #10655: Loading an older TSF file, shows the test configuration in readonly mode
- #10656: Include a menu entry in the help menu with a link to the available application notes on the RadiWiki website
- #10735: Not possible to select 3 dB filters on ESPI3.
- #10753: Drivers: MEB CDN's
- #10767: R&S FPL 1007 - Screen is not switched on by default. Have to turn it on manually.
- #10769: R&S FPL 1007 - The set value of attenuator is not set in the spectrum analyser. During measurements value is set to 0 dB.
- #10770: R&S FPL 1007: non CISPR detectors chosen for 200 hz and 1Mhz.
RadiMation version 2020.0.12[edit]
- #10768: Driver for PMM 9010/60P
- #10895: Issue 2020-04-01AL1_ra emission peak values dropped down in Diagramm
- #10909: Issue 2020-04-09 AL2_ OSD does not show current values of dwelltime in manual mode
- #10926: Change defaults in the stepper.
- #10927: Change default test level for the Calibrated Field Testlevel to V/m.
- #10928: Change default for modulation when you click activate modulation.
- #10933: The reportgenerator keeps searching for keywords in infinite loop when exporting the template directly after test
- #10966: Inn-Co CO 2000 (Unit 1): Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO).
- #10971: Issue 2020-04-09 AL2_ OSD does not show current values of calculated field in manual mode.
- #10976: Connection time-out when trying to connect to AR FA 7006
- #10979: Radiated immunity: Modulation and change mode are not displayed correctly.
- #10983: Driver: DARE!! Instruments RPR3006R
- #10989: R&S ESW8 Input 2, pulse limiter activation requires that DC Coupling is selected.
- #10990: Adjust Network Analyser Report Codes VSWR and ReturnLoss.
- #11005: Double click EUT file does not open in RadiMation.
- #11007: Dot and Comma issue when exporting data.
- #11010: Radimation Version 2020.0.011 Radiated Emission Manual - Antenna Factor.
- #11016: Agilent 8753: Specific System Error: 9, "CAUTION: LIST TABLE EMPTY".
- #11018: Antenna tower of Inn-CO CO3000 is not moving when controlled by Ethernet
RadiMation version 2020.0.11[edit]
- #10106: CISPR detectors are not selected or not selected correctly - ESU 8 - ESW26.
- #10650: Connection to CARAD not working
- #10659: BONN BLMA 1060-75-50: Add monitor command to the driver
- #10782: Pause Test alwas asks to save after closing it or when the counter is finished.
- #10812: Driver: Frankonia CDNE M2 / M3.
- #10827: Driver: Van veen loop.
- #10838: Polarizer battery empty errors are shown at inconvenient moments
- #10855: TDEM-X26 gets frozen after update driver package
- #10871: Issue 2020-03-26_AL2_mk Messtechnik OSD shows no output
- #10872: Error in RadiLog: Template (VARIABLEREPLACER.OBJ) Copied to:.
- #10874: TDEMI_X26: Specific System Error: -114,"Header Suffix Out of Range; SENS:SCAN4:STEP?
- #10875: TDEMI_X26: No match was found in the specified regular expression.
- #10878: Bonn amplifier is going into a loop
- #10884: Rohde & Schwarz ESW 8 Input 2 Time Domain: Specific System Error: -222,"Data out of range;SCAN1:STOP 1100000000 HZ"\n) using ESW8 Input2.
- #10885: Driver: add Rohde & Schwarz ESW Input 2 driver for powermeter.
- #10886: Driver: add Rohde & Schwarz ESR Input 2 driver for powermeter.
- #10887: Spectrum Analyser (ID1556) Input 2 (LAN): Impossible to get description string for this Error! Probably an unknown RadiMation Error. Code: 1073741975 (0x40000097)
- #10889: RI - Not possible to measure on points
- #10899: Ni cDAQ analog value max +-15 Vdc
- #10901: Temporarily disable the automatic calculation during the generation of an excel report.
- #10919: GTEM-1_SMB-100A: Impossible to get description string for this Error! Probably an unknown RadiMation Error. Code: 805317371 (0x30002AFB)
- #10923: Agilent Technologies N9038A Scanning Receiver: Specific System Error: -221,"Settings conflict; Step Size clipped to nearest value allowed.
- #10929: Rohde & Schwarz ESPI 3 Scanning Receiver (QTR:15): Specific System Error: -200,"Execution error; Function not available; BAND:TYPE NORM
- #10934: R&S ESR 7:Make sure that CISPR average is used in the pre-measurement when "Use CISPR detector is applicable".
- #10973: How to get the values for quasi-peak in my report
- #10978: Running Makro after generating data 2020.0.11
- #10993: Rohde & Schwarz FSV 3 BCI: Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO).
- #10994: How to include the markers of an emission test in the graph in a report?
- #10995: How to include the quasi peak limit line values in the emission table in the report?
- #10998: How can measurements for similar standards (CE & FCC) be done only once?
- #11001: Larger variation of field strength in Time graph compared to frequency graph
- #11006: RBW switches from 1MHz (fix) to Auto [120 kHz].
- #11021: How to specify a Current Sensor Correction File in dB
RadiMation version 2020.0.10[edit]
- #10605: Frequencies of injection and calibration jig are not remembered
- #10663: R&S ESU 26 - Execution error function not available;band:type norm
- #10842: Radilog file can't be bigger then 2 gb, after it will create a 0 bytes RadiLog file which can be sent
- #10846: Driver: Electro metrics 6913.
- #10866: Die arithmetische Operation hat einen ??berlauf verursacht.
- #10868: R&S ESCI: please add the option to swich DC coupling to the driver
RadiMation version 2020.0.9[edit]
- #10391: Driver: Schwarzbeck NFCN 9734 Switch Matrix Driver.
- #10833: Multiband Immunity graph does not look correct
- #10618: ||TIME; FREQUENCY;.TABLE 30 s|| works in 2017.2.7 not in 2019.1.9
- #10822: Radiated Immunity test doesn't show 1hz steps.
RadiMation version 2020.0.8[edit]
- #10646: Driver: Schwarzbeck CDN 801.
- #10807: Time and Date on the mk Messtechnick OSD are only displayed on output 2
- #10817: Radiated Emission manual mode uses the default unit for field which is defenided at radiated immunity
- #10829: Rohde & Schwarz NRP6AN (1-0944): Specific System Error: -148,"Character data not allowed; SENS1:FREQ 540000000 HZ
- #10831: Radiated Immunity MB with frequency list file shows incorrect power with hz steps.
RadiMation version 2020.0.7[edit]
- #3522: Agilent 8753ES is giving EABO error first time RadiMation starts
- #10521: Checking the driver for R&S NRX indicates that the device is not connected
- #10639: Driver: COM-Power CDN-T8SE (LISN).
- #10640: Driver: Schwarzbeck CAT5 8158 (LISN).
- #10641: Driver: COM-Power ISN T8.
- #10644: Driver: Rohde & Schwarz MDS 22.
- #10645: Driver: Minicircuits TIA-1000-1R8
- #10674: GAUSS TDEMI X - When using a step size of 100kHz the results do not match the results on the analyser
- #10687: Cannot find antenna tower in the currently active testsite .
- #10751: R&S ESW8 Pulse limiter on RF input 2.
- #10763: Formulas in the manual are not displayed correctly
- #10766: D.A.R.E!! Instruments RGN6000A: Setting the frequency raised an error
- #10786: Send Data To RGN2001A switch matrix ATT2 (9KHz-800MHz): Impossible to get description string for this Error! Probably an unknown RadiMation Error
- #10801: mk Messtechnick OSD driver of 2020.1.27.1708 is not sending any comments
- #10802: mk Messtechnick OSD shows random "black spots"
- #10803: Clearing a longer text from the mk Messtechnick OSD leaves the background color set
- #10804: modulation type is transmitted continuously to the mk Messtechnick OSD
- #10806: MK Messtechnick OSD is not cleared correctly
- #10808: Time and Date are always displayed on the mk Messtechnick OSD, even if the checkboxes are unchecked
- #10809: mk-Messtechnik on screen text display driver does not work
- #10816: Only rounded steps are possible when using a logarithmic step size.
- #10821: R&S ESI Powermeter can be improved when very small frequency steps are used
- #10826: Driver: Prana 25 S
RadiMation version 2020.0.6[edit]
- #8916: Agilent 33250 as external modulator
- #10365: Driver: TurnTable Siemens XYZ.
- #10426: Radimation callibration does not scale properly anymore.
- #10461: Change device driver names for Dare!! CDN's
- #10476: External 20 dB Attenuation: RS232: Setting the Baudrate attribute raised an error.
- #10484: N9038A: Not able to select more then one trace.
- #10485: Driver: Schwartzbeck CDN M2.
- #10486: Driver: Schwartzbeck CDN M3.
- #10487: Driver: Luthi CDN AF2.
- #10488: TESEQ T2-10.
- #10489: Driver: TESEQ A201A.
- #10490: Driver: Schloeder CDN M2-32A.
- #10492: Driver: TESEQ MD4070.
- #10493: Driver: Tektronix MDO 3014
- #10495: Driver: R&S FPL1000.
- #10501: LUMILOOP LS Probe 1.2: Device Not Connected.
- #10508: Possibility to remove the RadiMation logo from the emission graphs in the report?
- #10526: Driver: Schwarzbeck UBAA 9114
- #10538: Die Sammlung wurde geändert. Der Enumerationsvorgang kann möglicherweise nicht ausgeführt werden.
- #10592: The default port of the RadiCentre LAN is wrong.
- #10595: During rotation of turntable, the tabs on the Multiband test become disabled.
- #10602: Driver: AR JB6.
- #10603: Driver: AR 30S1G6.
- #10607: Driver: Horn Antenna ATH800M6G.
- #10610: R&S ESRP 3: 1st 2 peaks measured is with correct 120 RBW, 3th & 4th are measured with 100 kHz RBW
- #10623: Driver: MultiMeter Keysight 34450A.
- #10628: BBL200 idn check returns Rohde & Schwarz,BBA150.
- #10629: BBL200 Timeouts.
- #10666: Description for this error is not available. Error nr.: 536881313
- #10669: DARE!! Instruments RGN6000B HF (USB): Frequency tried to set is lower than the start frequency (9000 Hz) or higher than the end frequency (6000000000 Hz) of the device driver.
Known Problems[edit]
- Open the configuration window of RadiMation®
- Select the Device Drivers tab
- Select Receivers/Spectrum Analysers
- Select the R&S receiver
- Press Edit to open the device driver configuration window
- Press the Advanced button
- The GPIB configuration dialog of the R&S device driver will be shown
- Activate the Show advanced Settings checkbox
- The GPIB Configuration dialog will show a Wait time box
- Specify 3000 us in the Wait time box
