Release Notes 2021.2
Introduction
We are proud to deliver you Version 2021.2 of our RadiMation® EMC Test software. This 2021.2 version is the result of several major improvements that we have done.
This letter contains all the information that is needed before your system is upgraded. If you have any additional questions or remarks please let us know through your reseller, or contact radimation-support@raditeq.com.
Installation
Backup
- Correction files
- TSF files
- Sequence files
- Limit Line files
Multi version installation
Be advised that:
Installation
Installing software updates
Updating device drivers
Verification and Validation
1) Automatic knob pushing program
2) Validation and usage in a test lab
3) Validation and usage in a test house
4) Validation by end-users
Solved items
See below the list of all the issues that have been solved in RadiMation® version 2021.2 since version 2021.1
RadiMation version 2021.2.8
- #3971: Radiated emission multiband: click on "continuous measure" to disable function is taken twice quite often.
- #6698: Project: Improve Continuous measurement method.
- #11553: Underscore shortcut keys are not correctly assigned in field probe setup dialog
- #11604: Text that is shown in progress bar is dark grey, instead of black as in buttons.
- #11612: Binary block buffer retrieval over VISA Socket port is resulting in timeout
- #11687: WriteReadBinaryBlockBuffer causes timeout when TCPIP::x.x.x.x::port::SOCKET is used
- #11742: ErrorReport: "locked the gpib board".
- #11887: Measure time of 10ms is out of range.
- #12053: The device driver system is currently not usable
- #12072: ErrorReport: "Multiband Test one subrange not executed".
- #12082: Schwarzbeck CDN as injection device
- #12083: Include a check during startup to ensure that the Windows decimal separator is not "" (blank/nothing) or "0"
- #12084: Correction file with Frequency unit in kHz only shows half of the graph
- #12106: Send frequencies above 10 GHz to newer RadiSense 10 probes.
- #12108: Control channel selection of the radio dummy/fibre optic link of RFPA
- #12129: RepGen: Using a RunMacro keyword, results in the "" keyword not found event being presented
- #12133: Magnitude graph of S-parameter test shows an additional line going to 0
- #12134: Stop sequence: sequence is not correctly aborted when stop is pressed during a zero operation.
- #12135: Frequency scale is not full span.
- #12141: Resolution of R&S ESIB can be configured but only to 500 points
- #12142: Correction file: graph not displayed
- #12146: Rigol RSA5065A without EMI option can only measure a single trace
- #12160: Provide a configuration setting in the Narda EP600-series to configure the sleep mode time.
- #12173: Virtual Signal generator enables carrier on frequency change.
- #12174: Time-out Spurious emission measurement.
- #12181: Strange error on closing RadiPower driver.
- #12185: Rigol RSA5000 series, should allow to use 0 dB attenuation in combination with preamplifier
- #12186: Rigol RSA5065: When auto preamplifier is selected, it is reported as 0 dB, even though the preamplifier is on
- #12207: Reselect the limitline in the TSF file clears the max value customization of the graph.
- #12208: Driver: Tektronix RSA 306B.
- #12216: Error message that device driver system is not usable after a RadiSense error
- #12223: Driver: Prana IPDR250
- #12224: Driver: Prana CJDR250
RadiMation version 2021.2.7
- #4246: Possibility to insert note in "read only" protected TSF before mesurement starts
- #10935: CI manual mode. Make sure to set the settings of the signal generator when modulation is switched of and on so that this setting is imediatly applied
- #11373: DARE!! Development RadiSense IV: Device returned Error code : 4.
- #11739: Add option in R&S ESW driver to active low noise amplifier (for lower noise floor)
- #11846: Measured differences between RadiMation and PMM software when Testing CE/RE
- #12078: Absorbing clamp Maturo FCU: Function not implemented error
- #12087: Opening test data older than 2021.2.1 results in missing distance data
- #12088: ErrorReport: "RI with rot pos, 1 step, 120 degrees".
- #12091: Build RadiMation 2021.2.7
- #12144: Device driver configuration dialog cannot be shown, due to problem of loading GenericTabbedDialog
- #12147: How to disable the power delivery test, to prevent that generated frequencies are really in order
- #12165: Start Frequency is too low for the selected equipment
- #12211: Ability to use an automatic calkit for the R&S ZNB VNA calibration
- #12217: Agilent technologies U2004A driver problem: Insufficient location information
- #12219: Rohde & Schwarz NRP-Z91: Impossible to get description string for this Error! Probably an unknown RadiMation Error. Code: 805313470 (0x30001BBE)
- #12239: Driver: MTS Systemtechnik KRE-4000
- #12291: Question: Forward power amplifier protection file is not found
- #12293: Error message: There is no average probe selected
- #12295: Incorrect RBW of 1 MHz with QP detector in range 1GHz-6GHz
RadiMation version 2021.2.6
- #11795: Add ability to measure electrical fields of ~ +1000 V/m using a RadiSense
- #12040: Slow start of RadiMation Pulsed Immunity test
- #12064: ErrorReport: fault "System._ComObject"
RadiMation version 2021.2.5
- #11962: Distance unit text is missing in generated reports
- #11965: ErrorReport: "Antenna distance incorrect after upgrade to new version (2021-1-6 -> 2021-2-3)"
- #11988: ErrorReport: "Unable to see cable under test descripton"
- #12050: ErrorReport: "Cannot find positioner"
RadiMation version 2021.2.4
- #11806: RIGOL device driver is measuring too high AVG and QP detector values
RadiMation version 2021.2.3
- #9170: Some properties set in the polarGraph init function get reset when the graph is actually drawn
- #11892: Before/After actions Pauze window does not close it self, or by clicking the OK button.
RadiMation version 2021.2.2
- #11851: Minimum absorbing clamp distance is 1 mm. This should be changed to 0mm.
- #11854: Final measurement stops after first final measurement if distance graph is selected.
- #11855: If the default graph configuration is set to logarithmic, a strange x-axis is shown for distance graph
- #11856: If distance unit is set to cm, the frequency too high errors are generated in the distance graph
- #11857: The unit configuration of the distance is not used in the graph x-axis
- #11858: Limit line in the distance graph is shown as a curved line. This should be a straight line in the distance graph.
RadiMation version 2021.2.1
- #2273: Multiband Conducted emission absorbing clamp
- #5579: Stopping a sequence is almost impossible
Known Problems
R&S spectrum analysers/receivers communication problems
- Open the configuration window of RadiMation®
- Select the Device Drivers tab
- Select Receivers/Spectrum Analysers
- Select the R&S receiver
- Press Edit to open the device driver configuration window
- Press the Advanced button
- The GPIB configuration dialog of the R&S device driver will be shown
- Activate the Show advanced Settings checkbox
- The GPIB Configuration dialog will show a Wait time box
- Specify 3000 us in the Wait time box
Previous RadiMation® version raises a run-time error
Windows 8, Windows 7, XP, Vista and older are not supported
