Release Notes 2022.1
We are proud to deliver you Version 2022.1 of our RadiMation® EMC Test software. This 2022.1 version is the result of several major improvements that we have done.
This letter contains all the information that is needed before your system is upgraded. If you have any additional questions or remarks please let us know through your reseller, or contact radimation-support@raditeq.com.
Installation[edit]
Backup[edit]
When a RadiMation® file is opened, changed and saved in a newer version of RadiMation®, it is possible that it will be saved in a newer file format, which cannot be opened anymore in an older version of RadiMation®. To prevent that changed TSF, LLF, COR, SEQ or EUT files cannot be opened anymore in an older RadiMation® version, we strongly recommend to make a backup of the directories that contain those files. Before you install the latest version of RadiMation®, please make sure to safeguard all your critical data.
Make a back up of (at least) the following directories:
- Correction files
- TSF files
- Sequence files
- Limit Line files
Information on how to create a backup is available in RadiMation Application Note 152: Creating back-ups and restoring important RadiMation files.
Be advised that:
Installation[edit]
Updating device drivers[edit]
Solved items[edit]
See below the list of all the issues that have been solved in RadiMation® version 2022.1 since version 2021.3
RadiMation version 2022.1.4[edit]
- #12066: Driver: Keysight Fieldfox N9916B
- #12691: Antenna scan add Attenuation in table
- #12732: Correlated graph is not shown in Multiband GTEM measurement
- #12796: Scan resolution for Rigol RSA5065
- #12803: Error during uniform field calculation
- #12809: Initialisation of the devices (especially the Rigol RSA5065) takes a long time (approx. 13s).
- #12835: Use advanced option "Reduce.Buckets.Minimum" to create a fixed suggested index trace to increase the resolution of the shown graph data
- #12839: Keysight E5061B SA (Port 2) + HP1141 100x: Device Driver Function Not Implemented.
- #12853: NSG3040A Surge generator connection problem
- #12855: Device driver not implemented?
- #12889: Driver: Bonn BLWA 0860-160/100/50D.
- #12900: Scaling of CE Multiband is not using the full screen.
- #12903: Fluke 8840, is being measured too fast, which result in a worse accuracy
- #12904: GTEM correlation differences
- #12905: Correction file raises warning that the frequency is too high.
- #12907: CISPR CAV detector does not turn on
- #12908: Probe Connetion.
- #12916: Switching ports from 1/2 to T/R is setting the end frequency in override mode
- #12919: 'Continuous Measure' button remains to show 'Stopping continuous measure'
RadiMation version 2022.1.3[edit]
- #9088: USB communication with RadiCentre is disturbed by Lumiloop TCP Server
- #11501: Driver: R&S RTE1024 as powermeter
- #12020: Signal Generator Rohde&Schwarz SMCV100B
- #12131: Update Raditeq dongle in chapter 2 of the manual
- #12403: TSF RI limit line control, title of form is not shown, there is no OK button
- #12538: BAND selection for driver of IFI T82-250.
- #12557: Issues when starting tests using the EM-Test NX7
- #12669: Multiband of Absorbing clamp can not move to 6m.
- #12685: Primary GPIB address of 31 can be selected, while the maximum allowed primary GPIB address is 30
- #12688: Driver: Yokogawa DL750
- #12689: frmConfigTestLevelElectricalField uses wrong language resource id for the side button
- #12698: LISN Network implementation
- #12702: Stopping sequence
- #12705: Configurable Antenna Tower - Commands for height missing
- #12706: CISPR AV esw 8 time domain mode.
- #12707: Report Generator does not run correct for EFT tests
- #12714: Maturo FCU 3.0. Device driver not implemented
- #12718: MIL-STD Peak discrimination is always NB when a RBW above 100 kHz is used
- #12723: Start and stop frequency has changed during (de-)activation of the preamplifier
- #12725: Test not closed.
- #12729: Tektronix AFG3251C: Modulation frequency is not correctly set
- #12733: Data out of range
- #12734: Conducted Emission, data out of range
- #12744: Driver: Lumiloop 2.0+
- #12748: Frankonia AXL-200 raises error that device driver is unknown
- #12750: Schloder CDG6000 powermeter device driver shows wxWidgets debug window
- #12756: Initialisation of RadiSwitch takes a very long time when a Lumiloop is also connected
- #12757: Initialisation of RadiPos takes a very long time when a Lumiloop is also connected
- #12764: Extend the lumiloop LSProbe 2.0 driver to allow calibration of all 6 individual axis
- #12802: Ending a test without saving
RadiMation version 2022.1.2[edit]
- #5196: Allow to measure multiple detectors simultaneously during continuous measure
- #7849: Ability to save invalid TSF files and LLF files
- #11321: TSF file of Burst/Surge test cannot be saved when no cable is selected yet
- #11631: TSF cannot be saved if no protection key is present
- #11861: ErrorReport: "*.TSF file change without dongle not possible!"
- #11891: report generator text editor should not include RAW OADateTime values when generating reports
- #12151: Possibility to save an incomplete configured TSF file to disk
- #12158: RadiMation force closes when the process cannot acces the RadiLog file, because it is in use by another process.
- #12231: Driver: AFJ FFT3110.
- #12263: VI instrument window graph control are moved of the visible area when resizing the form
- #12321: Application note for close proximity magnetic field testing
- #12359: Save *.TSF file without dongle not possible!
- #12399: Error @ Restart last TSF
- #12402: Limit lines are not shown when applying filter settings
- #12404: Clean up invoke related code implemented on the RadiMation mainWindow
- #12406: Add notification bar too the MB field probe test level, stating that multiple probes will be averaged
- #12412: Device driver related UI components are not functioning as intented
- #12446: SpinUpDownControl shows white text on white background.
- #12464: Extend AD-Convertor driver for Tektronix TDS2000 series to allow USB connection.
- #12536: Dark skin white border at Note and Address information.
- #12539: issue 2022-03-30 AL1: frequency graph switch from log to lin after switching to Angle view.
- #12544: Sequence overview menu item stays active when cancelled.
- #12545: Connection problem
- #12553: TDEMI: Support multiple final detectors in parallel
- #12554: Ethernet Driver required for Agilent 33220A.
- #12576: Error final peak measurement R&S ESPI3 with RadiMation 2021.3.5
- #12588: When resizing the Pulse modulation configuration, the "Apply out of dwell time" is moved under the pulse gating frame
- #12601: Export of limitlines is showing a stepped instead of constant slope.
- #12603: No export was possible of measurement T21 due to out of memory.
- #12167: Validate LLF files at the start of test
- #12622: Start and stop frequency on UFA calculation printout are always zero
- #12623: Opening a unfinished PI data document will start a test without warning
- #12627: The maximum frequency is 10 GHz in the 'Free' and 'Essential' license types
- #12628: Control of an EUT controller is not allowed in the 'Essential' license type
- #12629: Control of a positioner is not allowed in the 'Essential' license type
- #12630: Change references to RadiMation Lite license to RadiMation Essential
- #12636: The about window shows that the RadiMation 'Pro' license is used
- #12637: Timeout while data transfer.
- #12641: CI calibration error.
- #12656: Logarithmic step frequency, starting from shows: -10000000000000 MHz
- #12661: Driver: RadiSwitch RSW1022V and RSW1024V.
- #12662: AM square wave modulation on Keysight N5171B generator.
- #12672: unable to split cells during template generation.
- #12700: Trial period of RadiMation Pro-error with start of test
- #12747: RS10 probe connect niet
- #12578: Antennerotator rotates to -3.8 degrees instead of 356.2 degrees
- #12762: How to change the Default Setting of Receiver Setting in the Software
- #12817: GPIB error: Hibernated NI drivers error. Restart your PC
- #4668: Allow to measure multiple detectors simultaneously during final measurement
RadiMation version 2022.1.1[edit]
- #9256: Update the SX32W to the latest version released by Safenet.
- #12125: The border of the non-maximized MDI child window is very narrow. Please enlarge it.
- #12126: Show the title bar of a passive MDI child window in a different colour than the active MDI child window
- #12127: Allow that end-user can select another skin.
- #12245: If only a single fieldprobe is measured, it will be used as the average field, even if it is not selected to be included in the average calculation
- #12278: RadiLog shows key-value pairs on the General tab instead of on the Input or Output tab
- #12282: Automatically focus the sequence overview window when the last test of the sequence is finished
- #12283: Option to select if the sequence window should remain open or close automatically.
- #12337: Copy the RadiPower USB drivers from DRIVERS.EXE to a sub-directory to allow manual driver installation.
- #12362: incorrect status info sequence.
- #12392: Skin is not applied correctly when switchen from the windows default to another skin.
- #12417: error while applying new skin.
- #12441: The corners of the buttons on the VI windows have white pixels in a dark skin.
- #12442: Unexpected borders are shown around buttons on some skins.
- #12444: Forms having a fixed light colour even using darker skins
- #12529: Driver: SCHAFFNER EMI Receiver SCR 3502 (RS232).
- #12534: AW: Export from Version 2021.3.5 => Out of Memory.
- #12631: The main window title bar includes 'RadiMation Essential' when the Essential license is used
- #12643: Voltage dips test
- #12663: Rohde & Schwarz BBA150 connection error
Known Problems[edit]
- Open the configuration window of RadiMation®
- Select the Device Drivers tab
- Select Receivers/Spectrum Analysers
- Select the R&S receiver
- Press Edit to open the device driver configuration window
- Press the Advanced button
- The GPIB configuration dialog of the R&S device driver will be shown
- Activate the Show advanced Settings checkbox
- The GPIB Configuration dialog will show a Wait time box
- Specify 3000 us in the Wait time box
