Release Notes 2023.1
We are proud to deliver you Version 2023.1 of our RadiMation® EMC Test software. This 2023.1 version is the result of several major improvements that we have done.
This letter contains all the information that is needed before your system is upgraded. If you have any additional questions or remarks please let us know through your reseller, or contact radimation-support@raditeq.com.
Installation[edit]
Backup[edit]
When a RadiMation® file is opened, changed and saved in a newer version of RadiMation®, it is possible that it will be saved in a newer file format, which cannot be opened anymore in an older version of RadiMation®. To prevent that changed TSF, LLF, COR, SEQ or EUT files cannot be opened anymore in an older RadiMation® version, we strongly recommend to make a backup of the directories that contain those files. Before you install the latest version of RadiMation®, please make sure to safeguard all your critical data.
Make a back up of (at least) the following directories:
- Correction files
- TSF files
- Sequence files
- Limit Line files
Information on how to create a backup is available in RadiMation Application Note 152: Creating back-ups and restoring important RadiMation files.
Be advised that:
Installation[edit]
Updating device drivers[edit]
Solved items[edit]
See below the list of all the issues that have been solved in RadiMation® version 2023.1 since version 2022.3
RadiMation version 2023.1.8[edit]
- #13843: AD-Converter Keithley (Scanner) shows error -133 undefined header on the display.
- #13847: Timeout error when using filter 12
- #13853: Events are not shown in the events tab of a multiband radiated immunity test
- #13864: RE MB test window - peaks tab is broken
- #13869: Conducted Emission MB test is raising a object reference error
- #13863: Driver: Amplifier Research FL8018 + FI8000
RadiMation version 2023.1.7[edit]
- #11939: Differences in the behavior of the shown test events between Singleband and Multiband
- #13426: TDEMI repeats measurement on frequency step for several times
- #13556: Driver: FPP 2,3/1.5 support for the Maturo FCU3.0 and NCD controller
- #13565: Readout of the TDEMI Gauss Ultra 6 seems to repeat the measured data
- #13599: AD-Converter Keithley (Scanner) shows error -133 undefined header on the display
- #13608: Editing in Note Tab not possible, only via "Note" button
- #13653: Saving the content of the note adds an additional newline character
- #13654: EUT information items should not allow items starting or ending with new line characters
- #13678: TDEMI U6 - Radiated Emission - measurement results contain noise not seen on the device.
- #13718: Different RBW values cannot be configured as expected because of auto completion of the value
- #13765: Driver: Lecroy WaveRunner 8038HD
- #13766: Driver: Keysight MSOS054A
- #13767: Driver: Lecroy HDO 6034-MS
- #13789: BB graph - setting of marker does not work
- #13792: Select another band after removing a band in a multiband test
- #13794: Cosmetic issues regarding the alignment labels in RI Multiband
- #13795: R&S ESR seems to hang when it starts a new scan in the 1GHz - 3GHz range but not in the 30MHz - 1GHz range
- #13800: Driver: Frankonia VLH-700B1
- #13801: Driver: R&S OSP320 switchmatrix
- #13804: Driver: ETS-Lindgren 7002-009
- #13812: Driver: Frankonia VLH coupler
- #13817: Auto filter is not available in the RadiPower RPR4000 series
- #13824: Cannot connect to Frankonia VLH amplifier
- #13825: Update DevExpress to 22.1.10
- #13827: GPIB delays
- #13831: about external square wave modulation
- #13833: Confirming a new to angle in the VI instrument windows by pressing enter does not result in movement
- #13837: Agilent 33521A: "Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)"
- #13840: Extend the Keithley 2000 with ethernet and visa.
RadiMation version 2023.1.6[edit]
- #13580: EP600 times out if the binary data returned contains a new line character
- #13666: Provide a more generic 'attenuator' and 'pulse limiter' device driver
- #13674: EMI Schaffner SCR3502 measures high peak values while measuring in the noise
- #13692: Invalid message when removing input from TSF
- #13709: TDEMI Cancel don't work in remote control
- #13744: Logging mode is not supported by this powermeter.
- #13748: Singleband Conducted immunity fixed voltage checks for a CI mill cal data document
- #13756: Include check in firmware update if RadiLink is connected to the external power supply
- #13768: Fixed step count stepper, only tests the first and last frequency of a band
- #13799: Graphline customizations are not remembered
- #13806: Signal power is sometimes empty in RI MB test result
RadiMation version 2023.1.5[edit]
- #13614: Firmware update of the RadiLink RLK3086R is not working because of differences in the software update protocol
- #13641: Automatic retrieval of Temperature/Pressure/Humidity sensors during start of test
- #13686: Table header are not included and symbols are not inserted into reports
- #13699: Connection Check Fail for Keysight N9038A
- #13707: SV: RadiMation object null reference error when using the export functionality
- #13716: RadiCentre version check Driver
- #13720 Test Keysight IO viFLush returning buffermask of value 128 using pre-release build
- #13721: Error in communication with Power meter
- #13723: When a RadiPower USB is unplugged from the PC, no error is shown in RadiMation
- #13727: Set the termination on read for the EP600 field probes
- #13728: EP601 Does not return correct field when using as ad input
- #13732: Amplifier goes in operate before zero off probe
- #13733: Correction of ep601 at 60 kHz is sent as 50 kHz
- #13751: Time out problem with the "EP 601" field probe
- #13782: RGN connection issue in USB controlled RadiCentre
RadiMation version 2023.1.4[edit]
- #8156: Auto discovery of RadiPower powermeters through the RadiMation device driver system API
- #11578: New directory name / description not remembered
- #12860: TSF file directories names are changed to "new directory-<index>"
- #13182: Driver: RadiPol antenna tower
- #13211: FPC1000 using the 'GTEM' test results in "Specific System Error: -113,"Undefined header" when selecting zero span
- #13236: Turn table angle in MK Messtechnik OSD
- #13248: Object null reference error during Radiated Immunity test while determining the input identifiers of the test level
- #13343: Multi-axis field probe read out
- #13375: Creating a sub TSF Directory with a new TSF file (network) results in an empty directory name with the file in the root directory
- #13410: Add a manual controlled XY positioner driver
- #13519: Windows error 128: There are no underlying child processes to wait for
- #13537: Radimation data storage error during test
- #13553: Issue 2023-04-04 AL3 Configuration AD-Converter Keithley (Scanner)
- #13564: Frankonia FC05 Polarization controller issue
- #13567: Update wxWidgets to 3.2.2.1
- #13577: Possibility to switch The FFT mode of the TDEMI
- #13582: Emission Graph as polar plot of angles
- #13594: Rohde & Schwarz SMB 100B: Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
- #13595: Create a python module for an EUT Status interface
- #13600: Magnetic field test according ISO 11452-8 using CWS500N3
- #13603: Driver: RadiLink RLK3086R
- #13615: How to measure an ADC during singleband tests
- #13616: AD-Converter Keithley (Scanner) the first measurement returns 0V which is incorrect
- #13628: Final QP-Measurement not working for more than 1 Pre-Measured Peak due to the RBW being changed by the device
- #13633: Extend TCP/IP status interface to allow passing of TestInfo.
- #13639: Driver: TDEMI M7/M7+
- #13642: 'device driver function not implemented error' during Radiated immunity Calibration
- #13643: Name of new sub-folder in TSF selection window is lost
- #13644: Cannot execute isotropic field measurement using XYZ axis correction data
- #13647: CI test is levelling down with NSG 4070
- #13655: Rohde & Schwarz SMB 100A fault: Not all bytes are written to the GPIB-Board within the timeout period (GPIB: EABO)
- #13656: RadiPol 2010A cannot control tower height
- #13657: Antenne toren
- #13658: List FSA as 'FS Antennentechnik'
- #13659: single band external modulation depth setting
- #13660: Create antenna tower driver for the RadiPol
- #13661: Auto detect the RadiLink RLK3086R
- #13662: Attenuation/Gain system calibration cannot be used with carrier level below -50
- #13664: IF overload
- #13670: Radisense IV & Dare RSS1006A errors driver does not enable axis before taking measurements
- #13671: Error message during initialization of CXA N9000B signal analyzer
- #13672: RadiSense driver does not enable axis before taking measurements
- #13673: AR FM/FL field probe does not measure any field
- #13675: Object reference not set when referencing the input identifiers of the test site
- #13677: RadiSense IV returns E3 when setting the filter settings.
- #13682: Buttons for Add/Delete monitoring input in testsite configuration are shown too low
- #13683: HI6105 only returns the X axis measurement results
- #13684: Error 4 when retrieving field with RadiSense 4
- #13696: Reading RadiSense 18 is slow
- #13697: Graph line colours are not remembered
- #13700: too much reflected power
- #13701: Signal generator error - R&S SMB 100A
- #13704: Communication with a RSS1018 in a RadiCentre 1 is very slow
- #13705: EUT Status Controller does not require that the response starts with TESTINFO
- #13706: Update screens shows new major while already up to date
- #13708: No communication with RadiCentre possible
- #13719: Object reference not set to an instance of an object
RadiMation version 2023.1.3[edit]
- #13459: Wrong value when measuring single final average detector from FPC1500
- #13534: Performance problems in 2022.1.3
- #13539: RadiSense Error 3 on LASER? command
- #13547: Design calibration import tool
- #13548: Implement calibration import tool
- #13549: Extend the calibration import tool to also support Schaffner calibration files
- #13550: Build 2023.1.x including Calibration import tool
- #13551: Document and explain how to import the calibration files from another software package
- #13583: Settings.ini has been corrupted
- #13611: Frankonia FC06.1 connection issue when initializing multiple driver instances on the same control unit
- #13702: RadiMation does not display correctly on non HD resolutions
RadiMation version 2023.1.2[edit]
- #6003: Check if a newer software version is available during startup
- #11491: When using field monitor application, no correction factors were used, despite them being selected
- #13314: Possibility to start a sequence from the commandline.
- #13444: Auto detect from Configuration screen does not update window.
- #13457: & in drivers release notes is shown as & in update check window
- #13576: Probe laser disconnect when testing above 1000 V/m
RadiMation version 2023.1.1[edit]
- #12695: Rename FormattedLong to FormattedInteger, Add new FormattedLong using int64 longs
- #12947: RadiMation slows down the PC after updating
- #13047: Starting RadiMation by opening an EUT-file, results in RadiLog not being able to start when requested
- #13255: Calculated electrical field using horn antenna, shows different measurement values when a test file is reopened
Known Problems[edit]
- Open the configuration window of RadiMation®
- Select the Device Drivers tab
- Select Receivers/Spectrum Analysers
- Select the R&S receiver
- Press Edit to open the device driver configuration window
- Press the Advanced button
- The GPIB configuration dialog of the R&S device driver will be shown
- Activate the Show advanced Settings checkbox
- The GPIB Configuration dialog will show a Wait time box
- Specify 3000 us in the Wait time box
