Tests.AntennaTowerHeight.Both.Physical.Minimum
This advanced option specifies the minimum height where the antenna can move to when the antenna is horizontally or vertically polarized. RadiMation® version 5.8 will question the antenna tower controller it's minimum physical allowed height. The retrieved minimum antenna tower controller height and the value of Tests.AntennaTowerHeight.Both.Physical.Minimum will be used to determine the minimum height to which the antenna will be controlled. The highest of the two values is used.
The default value of Tests.AntennaTowerHeight.Both.Physical.Minimum is set to 0.8 meter, which ensures that any antenna is not controlled below 0.8 meter. This default value is by purpose specified as a relatively small value to prevent unwanted limitations.
If (for any reason) a limitation of the antenna tower height is needed higher than the minimum physical antenna height of the antenna tower controller itself, the value of Tests.AntennaTowerHeight.Both.Physical.Minimum can be set to a value that is higher than the limitation in the antenna tower controller itself. If for example the value of Tests.AntennaTowerHeight.Both.Physical.Minimum is set to 1, RadiMation® will never to move the antenna to a height below 1 meter.
There are other advanced options available that are related to this advanced option:
- Tests.AntennaTowerHeight.Both.Physical.Maximum
- Tests.AntennaTowerHeight.Both.Physical.Minimum
- Tests.AntennaTowerHeight.Changing.Physical.Maximum
- Tests.AntennaTowerHeight.Changing.Physical.Minimum
- Tests.AntennaTowerHeight.Horizontal.Physical.Maximum
- Tests.AntennaTowerHeight.Horizontal.Physical.Minimum
- Tests.AntennaTowerHeight.Vertical.Physical.Maximum
- Tests.AntennaTowerHeight.Vertical.Physical.Minimum
- Tests.AntennaTowerHeight.Unknown.Physical.Maximum
- Tests.AntennaTowerHeight.Unknown.Physical.Minimum
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
