Tests.AntennaTowerHeight.Horizontal.Physical.Minimum
This advanced option specifies the minimum height where the antenna can move to when the antenna is horizontally polarized. RadiMation® version 5.8 will question the antenna tower controller it's minimum physical allowed height. The retrieved minimum antenna tower controller height and the value of Tests.AntennaTowerHeight.Horizontal.Physical.Minimum will be used to determine the minimum height to which the antenna will be controlled. The highest of the two values is used.
The default value of Tests.AntennaTowerHeight.Horizontal.Physical.Minimum is set to 0.8 meter, which ensures that any antenna is not controlled below 0.8 meter. This default value is by purpose specified as a relatively small value to prevent unwanted limitations.
If (for any reason) a limitation of the antenna tower height is needed higher than the minimum physical antenna height of the antenna tower controller itself, the value of Tests.AntennaTowerHeight.Horizontal.Physical.Minimum can be set to a value that is higher than the limitation in the antenna tower controller itself. If for example the value of Tests.AntennaTowerHeight.Horizontal.Physical.Minimum is set to 1, RadiMation® will never to move the antenna to a height below 1 meter.
There are other advanced options available that are related to this advanced option:
- Tests.AntennaTowerHeight.Both.Physical.Maximum
- Tests.AntennaTowerHeight.Both.Physical.Minimum
- Tests.AntennaTowerHeight.Changing.Physical.Maximum
- Tests.AntennaTowerHeight.Changing.Physical.Minimum
- Tests.AntennaTowerHeight.Horizontal.Physical.Maximum
- Tests.AntennaTowerHeight.Horizontal.Physical.Minimum
- Tests.AntennaTowerHeight.Vertical.Physical.Maximum
- Tests.AntennaTowerHeight.Vertical.Physical.Minimum
- Tests.AntennaTowerHeight.Unknown.Physical.Maximum
- Tests.AntennaTowerHeight.Unknown.Physical.Minimum
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
