Immunity.Regulation.CalculatedGain.UseDefault
This advanced option specifies if the Immunity.Regulation.CalculatedGain.Default will be used as the 'calculated gain' for the amplifier, if no known 'calculated gain' is available, or if the known 'calculated gain' is out of the allowed values.
By default this value is set to 'True'. If the value is set to 'False', the 'calculated gain' of the amplifier will be limited to the Immunity.Regulation.CalculatedGain.Min and Immunity.Regulation.CalculatedGain.Max values, or it is assumed to be 1.0.
There are other advanced options available that are related to the regulation of the desired power in an immunity tests.
- Immunity.Regulation.PositiveTolerance
- Immunity.Regulation.NegativeTolerance
- Immunity.Regulation.WarningNegative
- Immunity.Regulation.MinimumStep
- Immunity.Regulation.MaximumStep
- Immunity.Regulation.MaximumNegativeStep
- Immunity.Regulation.MaximumDirectionChangeCount
- Immunity.Regulation.CalculatedGain.Use
- Immunity.Regulation.CalculatedGain.Default
- Immunity.Regulation.CalculatedGain.Min
- Immunity.Regulation.CalculatedGain.Max
- Immunity.Regulation.CalculatedGain.UseDefault
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
