Immunity.Regulation.CalculatedGain.Max
Jump to: navigation, search
This advanced option specifies the maximum accepted 'calculated gain' of the amplifier. If the actual calculated gain of the amplifier is higher, the value of Immunity.Regulation.CalculatedGain.Default will be used as the 'calculated gain'.
By default this value is set to 10.
There are other advanced options available that are related to the regulation of the desired power in an immunity tests.
Warning: Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully!
