Immunity.Regulation.MaximumStep
This advanced option specifies the maximum change (in dB) that will be taken with the carrier level of the signal generator in a single carrier level change going up during the regulation to the desired power in a immunity test.
By default this value is set to 5 dB.
There are other advanced options available that are related to the regulation of the desired power in an immunity tests.
- Immunity.Regulation.PositiveTolerance
- Immunity.Regulation.NegativeTolerance
- Immunity.Regulation.WarningNegative
- Immunity.Regulation.MinimumStep
- Immunity.Regulation.MaximumStep
- Immunity.Regulation.MaximumNegativeStep
- Immunity.Regulation.MaximumDirectionChangeCount
- Immunity.Regulation.CalculatedGain.Use
- Immunity.Regulation.CalculatedGain.Default
- Immunity.Regulation.CalculatedGain.Min
- Immunity.Regulation.CalculatedGain.Max
- Immunity.Regulation.CalculatedGain.UseDefault
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
