Immunity.Regulation.NegativeTolerance
This advanced option specifies the accepted tolerance for leveling the power. This is the tolerance (specified in dB) of the power accepted below the required level, and is used during the regulation to the desired power in a immunity test.
By default this value is set to 0.0 dB.
There are other advanced options available that are related to the regulation of the desired power in an immunity tests.
- Immunity.Regulation.PositiveTolerance
- Immunity.Regulation.NegativeTolerance
- Immunity.Regulation.WarningNegative
- Immunity.Regulation.MinimumStep
- Immunity.Regulation.MaximumStep
- Immunity.Regulation.MaximumNegativeStep
- Immunity.Regulation.MaximumDirectionChangeCount
- Immunity.Regulation.CalculatedGain.Use
- Immunity.Regulation.CalculatedGain.Default
- Immunity.Regulation.CalculatedGain.Min
- Immunity.Regulation.CalculatedGain.Max
- Immunity.Regulation.CalculatedGain.UseDefault
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
