Immunity.Regulation.WarningNegative
This advanced option specifies the value when the levelled power is more than the specified value (in dB) below the desired test-level, that a warning will be generated
By default this value is set to 0.1 dB.
There are other advanced options available that are related to the regulation of the desired power in an immunity tests.
- Immunity.Regulation.PositiveTolerance
- Immunity.Regulation.NegativeTolerance
- Immunity.Regulation.WarningNegative
- Immunity.Regulation.MinimumStep
- Immunity.Regulation.MaximumStep
- Immunity.Regulation.MaximumNegativeStep
- Immunity.Regulation.MaximumDirectionChangeCount
- Immunity.Regulation.CalculatedGain.Use
- Immunity.Regulation.CalculatedGain.Default
- Immunity.Regulation.CalculatedGain.Min
- Immunity.Regulation.CalculatedGain.Max
- Immunity.Regulation.CalculatedGain.UseDefault
| Warning: | Any change and/or modification to the advanced options, can result in unexpected results and/or incorrect measurement results. Changes in any advanced option should be verified and checked very carefully! |
