Chapter 2
(Redirected from Getting Started)
Getting started[edit]
Software overview[edit]
  • The Visual and Graph System
  • Sequence Testing
  • Calibration
  • Data Logging
  • Database Functionality
  • The Device Driver System
  • Different types of tests can be performed, fully automatically, after each other (Sequence testing).
Conventions[edit]
   Menu.svg File
      Menu.svg Open
         Menu.svg EUT
Hardware requirements[edit]
The RadiMation® software makes extensive use of data calculations, bus interactions (to control the test equipment) and screen interactions (for the use of graphs). Because of this the processor performance is very important and a dedicated PC for RadiMation® is required. Running other programs on the same computer can cause compatibility problems and is not supported. Programs which are supported are the programs used by RadiMation®, such as Microsoft Word, Excel and MySQL.
  • Processor architecture: x64 (ARM64 is not supported)
  • Processor clock speed: 2 GHz minimum, > 3 GHz recommended
  • Free RAM memory: 2 GB minimal, > 4 GB recommended
Memory[edit]
RadiMation® needs a considerable amount of memory to perform at its best. We recommend that you have at least 2 GB (GigaBytes) of free memory available, but more if possible. Free memory is defined as the amount of free RAM without having to use the swap file. Thus, not the specification of the total amount of memory that the machine has. The following steps are to help you determine the amount of free memory in your PC:
If the amount of free memory is less then 2 GB, there are several options to obtain more free memory. Depending on the configuration and situation, the following options are available:
GPIB card[edit]
Software requirements[edit]
The Microsoft .NET Framework 4.8 is also required. For all supported Windows operating systems, this is already installed by default.
Microsoft office[edit]
It is required to have a supported, licensed and working version of Microsoft Office Word installed on the PC. This should be at least Microsoft Word 2016 or higher, as Microsoft Word 2013 and lower has no mainstream support anymore from Microsoft. RadiMation® uses Microsoft Office Word to generate and print the printouts, besides creating the reports. The RadiMation® report generator can create reports in the following formats:
Installation[edit]
Software installation[edit]
    • CAL_File
    • CONFDVDR
    • COR_File
    • EUT_File
    • LLF_File
    • Printout
    • RGO_File
    • RGT_File
    • SEQ_File
    • TSF_File
Note: We strongly advice to make a complete backup of all user files and directories (e.g. Device driver configuration files/TSF/Sequence/Correction/Calibration and EUT files) before installing a RadiMation® update.
Updating device drivers[edit]
New installation[edit]
Update[edit]
To update the RadiMation® software, the user must have the rights to read and write in the RadiMation® folder, which is normally located in the 'C:\Program Files (x86)\Raditeq\' directory.
Daily usage[edit]
Software protection key[edit]
Software configuration[edit]
Password protection[edit]
  • The configured engineers are stored in the Device Driver Configuration Files directory, which can be configured using the menu:
   Menu.svg Configuration
         Menu.svg Directories
Test engineers[edit]
  • The default client
  • The default manufacturer
  • The default test site
Default Units[edit]
  • Radiated Immunity
  • Conducted Immunity
  • Radiated Emission
  • Conducted Emission
  • Pulsed Immunity
  • Antenna Diagram
  • RadiCal
Graphics configuration[edit]
Database Configuration[edit]
Language Selection[edit]
RadiMation® supports multi-language use. This means that the software package can be operated in several different languages.
In addition, the multi-language support allows for easy translation from English to most other languages.
Product Standard[edit]
Basic Standard[edit]
To delete a piece of test equipment from RadiMation®, select the Test Equipment from the pull down menu and click the 'Delete' button in the top of the window. A confirmation window will appear.
A menu will open (at your mouse pointer) with the available devices for that Device Type.
Edit the information about your ‘user configurable device driver’ in the 'Device Driver Settings' window.
  • Frequency range
  • Maximum input power
EUT files[edit]
Creating a new EUT file[edit]
EUT window overview[edit]
Limit line files[edit]
Creating limit lines[edit]
Saving limit line files[edit]
Correction files[edit]
In between the specified frequency points, the correct value of the correction value will be calculated by using either a logarithmic or linear interpolation over the frequency axis. This depends on the requirements of the applicable standard.
Saving correction files[edit]
Viewing test data[edit]
  • Time and date of the test
  • Test engineer
  • Notes
  • Ambient information
  • Test graphs
  • Test configuration data
Printing test data[edit]
Report generation[edit]
Ambient information[edit]
The first test[edit]
